Hallo @ all,
I use the cuda 4.0 compiler and the cuda 4.0 cufft library. If I use the inverse 2D CUFFT_Z2Z function, then I get an incorrect result. The imaginary part of the result is always 0. I cant believe this. I checked the complex input data, but i cant find a mistake.
Here is my code:
int NX =512;
int NY = 512;
cufftHandle Inverse_2D_FFT_Plan;
cufftSafeCall( cufftPlan2d(&Inverse_2D_FFT_Plan, NX, NY, CUFFT_Z2Z) );
cufftSafeCall( cufftExecZ2Z(Inverse_2D_FFT_Plan, idata, odata, CUFFT_INVERSE) );
If I use the inverse 2D CUFFT_Z2Z function then the imaginary part of the result is always 0. → Is this a knowing error?
