I’m following the README.md in d3-jetson-bsp-D3-RELEASE-5.0.0/doc.
I want to be able to compile the kernel and flash it to the unit.
While running the command:
checking for /home/michele/nvidia/nvidia_sdk/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/flash.sh… no
configure: WARNING: flash.sh not found — signing and syncing may not work
Here’s the configuration shown at the end of the configure command:
-D3 Configuration-
Customer : d3
Version : 5.0.0
System Type : xavier
Target Host : 192.168.55.1
DTB File : /home/michele/work/d3-jetson-bsp-D3-RELEASE-5.0.0/build/deploy/boot/d3-xavier-16x-fpdlink.dtb
L4T Directory : /home/michele/nvidia/nvidia_sdk/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS
Linux Version : 4.9.253
Username on tgt :
make[1]: Entering directory ‘/home/michele/work/d3-jetson-bsp-D3-RELEASE-5.0.0’
make[1]: *** No rule to make target ‘/home/michele/work/d3-jetson-bsp-D3-RELEASE-5.0.0/build/deploy/boot/d3-xavier-16x-fpdlink.dtb’’, needed by ‘sign-dtb’. Stop.
make[1]: Leaving directory ‘/home/michele/work/d3-jetson-bsp-D3-RELEASE-5.0.0’
make: *** [Makefile:910: deploy] Error 2
How can this be fixed?
I decided to ignore this error since the file d3-xavier-16x-fpdlink.dtb exists in build/kernel/arch/arm64/boot/dts/d3-xavier-16x-fpdlink.dtb with the correct time stamp.
I’m trying to follow the README.md that came with this release.
Any ideas would be appreciated.
