I refer to the code of deepstream-app, and implemented it, can open the USB camera, but it is very stuck
On jetson orin platform
deepstream6.2
I refer to the code of deepstream-app, and implemented it, can open the USB camera, but it is very stuck.
  1. I use the v4l2-ctl -d /dev/video1 --list-formats-ext command to view the parameters of the camera, and it supports the YVYU format.
  2. My pipeline is consistent with deepstream_source_bin.c
    cap_filter1: YUY2
    cap_filter: NV12
    pipeline: src_elem->cap_filter1->nvvidconv1->nvvidconv2->cap_filter
  3. The reference code is as follows:
static gboolean
create_camera_source_bin (NvDsSourceConfig * config, NvDsSrcBin * bin)
  GstCaps *caps = NULL, *caps1 = NULL, *convertCaps = NULL;
  gboolean ret = FALSE;
  switch (config->type) {
    case NV_DS_SOURCE_CAMERA_CSI:
      bin->src_elem =
          gst_element_factory_make (NVDS_ELEM_SRC_CAMERA_CSI, "src_elem");
      break;
    case NV_DS_SOURCE_CAMERA_V4L2:
      bin->src_elem =
          gst_element_factory_make (NVDS_ELEM_SRC_CAMERA_V4L2, "src_elem");
      bin->cap_filter1 =
          gst_element_factory_make (NVDS_ELEM_CAPS_FILTER, "src_cap_filter1");
      if (!bin->cap_filter1) {
        NVGSTDS_ERR_MSG_V ("Could not create 'src_cap_filter1'");
        goto done;
      caps1 = gst_caps_new_simple ("video/x-raw",
          "width", G_TYPE_INT, config->source_width, "height", G_TYPE_INT,
          config->source_height, "framerate", GST_TYPE_FRACTION,
          config->source_fps_n, config->source_fps_d, NULL);
      break;
    default:
      NVGSTDS_ERR_MSG_V ("Unsupported source type");
      goto done;
  if (!bin->src_elem) {
    NVGSTDS_ERR_MSG_V ("Could not create 'src_elem'");
    goto done;
  bin->cap_filter =
      gst_element_factory_make (NVDS_ELEM_CAPS_FILTER, "src_cap_filter");
  if (!bin->cap_filter) {
    NVGSTDS_ERR_MSG_V ("Could not create 'src_cap_filter'");
    goto done;
  caps = gst_caps_new_simple ("video/x-raw", "format", G_TYPE_STRING, "NV12",
  if (config->type == NV_DS_SOURCE_CAMERA_CSI) {
    GstCapsFeatures *feature = NULL;
    feature = gst_caps_features_new ("memory:NVMM", NULL);
    gst_caps_set_features (caps, 0, feature);
  struct cudaDeviceProp prop;
  cudaGetDeviceProperties(&prop, config->gpu_id);
  if (config->type == NV_DS_SOURCE_CAMERA_V4L2) {
    GstElement *nvvidconv2;
    //Check based on igpu/dgpu instead of x86/aarch64
    GstElement *nvvidconv1 = NULL;
    if(!prop.integrated) {
      nvvidconv1 = gst_element_factory_make ("videoconvert", "nvvidconv1");
      if (!nvvidconv1) {
        NVGSTDS_ERR_MSG_V ("Failed to create 'nvvidconv1'");
        goto done;
    g_object_set (G_OBJECT (bin->cap_filter), "caps", caps, NULL);
    g_object_set (G_OBJECT (bin->cap_filter1), "caps", caps1, NULL);
    nvvidconv2 = gst_element_factory_make (NVDS_ELEM_VIDEO_CONV, "nvvidconv2");
    if (!nvvidconv2) {
      NVGSTDS_ERR_MSG_V ("Failed to create 'nvvidconv2'");
      goto done;
    g_object_set (G_OBJECT (nvvidconv2), "gpu-id", config->gpu_id,
        "nvbuf-memory-type", config->nvbuf_memory_type, NULL);
      gst_bin_add_many (GST_BIN (bin->bin), bin->src_elem, bin->cap_filter1,
          nvvidconv1, nvvidconv2, bin->cap_filter,
          NULL);
    } else {
          nvvidconv2, bin->cap_filter, NULL);
    NVGSTDS_LINK_ELEMENT (bin->src_elem, bin->cap_filter1);
      NVGSTDS_LINK_ELEMENT (bin->cap_filter1, nvvidconv1);
      NVGSTDS_LINK_ELEMENT (nvvidconv1, nvvidconv2);
    } else {
      NVGSTDS_LINK_ELEMENT (bin->cap_filter1, nvvidconv2);
    NVGSTDS_LINK_ELEMENT (nvvidconv2, bin->cap_filter);
    NVGSTDS_BIN_ADD_GHOST_PAD (bin->bin, bin->cap_filter, "src");
  } else {
    gst_bin_add_many (GST_BIN (bin->bin), bin->src_elem, bin->cap_filter, NULL);
    NVGSTDS_LINK_ELEMENT (bin->src_elem, bin->cap_filter);
      if (!set_camera_csi_params (config, bin)) {
        NVGSTDS_ERR_MSG_V ("Could not set CSI camera properties");
        goto done;
      break;
      if (!set_camera_v4l2_params (config, bin)) {
        NVGSTDS_ERR_MSG_V ("Could not set V4L2 camera properties");
        goto done;
      break;
    default:
      goto done;
  ret = TRUE;
  GST_CAT_DEBUG (NVDS_APP, "Created camera source bin successfully");
done:
  if (caps)
    gst_caps_unref (caps);
  if (convertCaps)
    gst_caps_unref (convertCaps);
  if (!ret) {
    NVGSTDS_ERR_MSG_V ("%s failed", __func__);
  return ret;
Please refer to DeepStream SDK FAQ - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums
