I reported an error when I finished converting my onnx model Cuda Runtime (an illegal memory access was encountered)
I look at the logs and don’t know the cause of the error
root@sqn-desktop:~/DeepStream-Yolo# deepstream-app -c deepstream_app_config.txt
Opening in BLOCKING MODE
0:00:06.579829327  4542 0xaaaae771a4a0 INFO                 nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1909> [UID = 1]: deserialized trt engine from :/root/DeepStream-Yolo/model_b1_gpu0_fp32.engine
WARNING: [TRT]: The getMaxBatchSize() function should not be used with an engine built from a network created with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag. This function will always return 1.
INFO: [Implicit Engine Info]: layers num: 2
0   INPUT  kHALF  images          3x640x640
1   OUTPUT kHALF  output0         14x8400
0:00:06.653960170  4542 0xaaaae771a4a0 INFO                 nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2012> [UID = 1]: Use deserialized engine model: /root/DeepStream-Yolo/model_b1_gpu0_fp32.engine
0:00:06.665835751  4542 0xaaaae771a4a0 INFO                 nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/root/DeepStream-Yolo/config_infer_primary_yoloV8.txt sucessfully
Runtime commands:
        h: Print this help
        q: Quit
        p: Pause
        r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
      To go back to the tiled display, right-click anywhere on the window.
**PERF:  FPS 0 (Avg)
**PERF:  0.00 (0.00)
** INFO: <bus_callback:239>: Pipeline ready
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
** INFO: <bus_callback:225>: Pipeline running
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
ERROR: [TRT]: 1: [reformatRunner.cpp::execute::613] Error Code 1: Cuda Runtime (an illegal memory access was encountered)
ERROR: Failed to enqueue trt inference batch
ERROR: Infer context enqueue buffer failed, nvinfer error:NVDSINFER_TENSORRT_ERROR
0:00:07.549146757  4542 0xaaaae72dda40 WARN                 nvinfer gstnvinfer.cpp:1388:gst_nvinfer_input_queue_loop:<primary_gie> error: Failed to queue input batch for inferencing
ERROR: Failed to make stream wait on event, cuda err_no:700, err_str:cudaErrorIllegalAddress
ERROR: Preprocessor transform input data failed., nvinfer error:NVDSINFER_CUDA_ERROR
0:00:07.549650253  4542 0xaaaae72dda40 WARN                 nvinfer gstnvinfer.cpp:1388:gst_nvinfer_input_queue_loop:<primary_gie> error: Failed to queue input batch for inferencing
ERROR from primary_gie: Failed to queue input batch for inferencing
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(1388): gst_nvinfer_input_queue_loop (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie
0:00:07.549925394  4542 0xaaaae72dda40 WARN                 nvinfer gstnvinfer.cpp:1388:gst_nvinfer_input_queue_loop:<primary_gie> error: Failed to queue input batch for inferencing
Quitting
nvstreammux: Successfully handled EOS for source_id=0
Cuda failure: status=4
Error(-1) in buffer allocation
** (deepstream-app:4542): CRITICAL **: 11:38:34.278: gst_nvds_buffer_pool_alloc_buffer: assertion 'mem' failed
• DeepStream Version
• TensorRT Version
• The pipeline being used
Looks like something went wrong with the model conversion.
Please provide complete information as applicable to your setup First.
This problem relate with device and software version.
The problem has been found, it is related to my model
