I run the GLIFR_SimpleH264 sample,the h264 stream looks bad.Who knows the reasons?Thanks!
This is a video capture,triangle edge looks fuzzy.After the H264 encoding, the picture is very serious losses.
This is my code:
static void display()
char textBuffer[32];
float elapsedTime;
uintptr_t dataSize;
const void *data;
if (startTime == 0)
    startTime = getTimeInuS();
// Draw a colored cube to the FBO
glBindFramebuffer(GL_FRAMEBUFFER, fboID);
glViewport(0, 0, fboWidth, fboHeight);
glClear(GL_COLOR_BUFFER_BIT| GL_DEPTH_BUFFER_BIT);
glColor3f(0, 0, 1);
glBegin(GL_LINE_LOOP);
glVertex2f(1, 0);
glVertex2f(1, 1);
glVertex2f(0, 1);
glVertex2f(0, 0);
glEnd();
glBegin(GL_TRIANGLES);
glVertex2f(0.3f, 0);
glVertex2f(0.7f, 0);
glVertex2f(0.5f, 0.4f);
glEnd();
glBindFramebuffer(GL_FRAMEBUFFER, 0);
// transfer the FBO
if (nvIFR.nvIFROGLTransferFramebufferToH264Enc(transferObjectHandle, NULL,
	fboID, GL_COLOR_ATTACHMENT0, GL_NONE) != NV_IFROGL_SUCCESS)
    fprintf(stderr, "Failed to transfer data from the framebuffer.\n");
    exit(-1);
// lock the transferred data
if (nvIFR.nvIFROGLLockTransferData(transferObjectHandle, &dataSize, &data) != NV_IFROGL_SUCCESS)
    fprintf(stderr, "Failed to lock the transferred data.\n");
    exit(-1);
// write to the file
if (isOutFile)
    fwrite(data, 1, dataSize, outFile);
// release the data buffer
if (nvIFR.nvIFROGLReleaseTransferData(transferObjectHandle) != NV_IFROGL_SUCCESS)
    fprintf(stderr, "Failed to release the transferred data.\n");
    exit(-1);
frameCounter++;
elapsedTime = (float)(getTimeInuS() - startTime) / 1000000;
// print the frame rate every second
if (elapsedTime - lastUpdateTime > 1.f)
    float frameRate;
    frameRate = (float)(frameCounter - lastUpdateFrame) / (elapsedTime - lastUpdateTime);
    lastUpdateFrame = frameCounter;
    lastUpdateTime = elapsedTime;
    // draw the frame rate to the window
    glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
    glViewport(0, 0, winWidth, winHeight);
    snprintf(textBuffer, sizeof(textBuffer), "Encoding %dx%d at %4.0f fps\n", fboWidth, fboHeight, frameRate);
    printText(0, winHeight - 12, textBuffer);
    glutSwapBuffers();
time(&end);
if ((duration > 0) && ((end - start) > duration))
    if (isOutFile)
        fclose(outFile);
    deinit();
    exit(0);
else if ((numFrames > 0) && (frameCounter >= (unsigned int)numFrames))
    if (isOutFile)
        fclose(outFile);
    deinit();
    exit(0);
this is great.
