Hardware Platform: Jetson Xavier Nx
DeepStream Version: DeepStream-6.1
JetPack Version (valid for Jetson only) : 5.0.2 GA
TensorRT Version: 8.4.1.5
Issue Type( questions, new requirements, bugs) :
I tried using splitmuxsink to save the file. If there is one or more offline RTSP sources, the process will block a few seconds after I try to start deepstream-app.
This doesn’t happen when I use filesink.
How should I modify it.
Which deepstream demo did you run and how to use offline RTSP sources? If we can repro the problem in our env, We can analyze quickly.
The pipeline you posted cannot be seen clearly after being enlarged.
1.I run deepstream-app and I replaced mux and filesink with splitmuxsink.
2.I used 4 rtsp sources in config, and I turned off one or more of them to power down the camera that are not connected to the Internet. Then start deepstream-app and the process will block.
3.The deepstream-app will reconnect to the rtsp source that are not connected to the Internet. After a few reconnections, it will block.
