I WANT TO FIND OUT WHICH DRIVER API'S ARE USED INTERNALLY WHILE USING A SPECIFIC RUNTIME API?
HOW CAN I FIND THE DRIVER API’S WHICH ARE CALLED INTERNALLY WHEN USING A SPECIFIC RUNTIME API ? WHAT CAN BE THE METHOD THROUGH WHICH I CAN MAP RUNTIME API’S WITH CORRESPONDING DRIVER API’S ?
Please do not use All Caps, or your posts might get removed due to forum policies.
You need to be more specific about what you would like to achieve and which APIs you are using for anyone to be able to help you.
okay sir undestood i wont be using caps from the next time i post something
actually i have been documenting all the runtime as well as driver api’s and i wanted to find out about ways or tools to learn about the corresponding driver api’s which are invoked when we use a runtime api in a code/program.
