We are reviewing the AGX Orin schematic for our carrier board schematic.
As you can see below,
There are many capacitors attached, but U9’s datasheet lacks guidelines.
Based on what criteria were the capacitance values and the number of capacitors determined?
“Can you give a simple explanation?”
We need guidance on the Decoupling Capacitance value and quantity to be applied to the VCC_SRC (SYS_VIN_HV, 12V) supply.
If we build a circuit with the conditions below, can you give me some guidance on the decoupling capacitors?
The carrier board we are designing will be powered by 12V power directly from the SMPS.
In other words, the VCC_DCIN – VCC_SRC_FET – VCC_SRC power supply will be fixed to 12V and not variable.
Also, we will not be using the x16 PCIe Connector.
So we do not want to use the VDD_12V (Page 35) of the P3737(P3737_A05_OrCAD_schematics(base_version).pdf) reference circuit.
At this time, we are asking this question because we do not see any circuit that can provide appropriate decoupling time to VCC_SRC, excluding the corresponding capacitance in the VDD_12V circuit diagram.
