I want to know the include and lib path of tensorrt installed by jetpack
Here is the info:
INC path: /usr/include/aarch64-linux-gnu/
LIB path: /usr/lib/aarch64-linux-gnu/
Thanks you ! By the way, I also want to know the lib path of cudnn. I have two cuda folders, one is named cuda and the other is named cuda11.4. I want to know if they are the same, it seems like there is no difference when I run other software.
CUDA folder is /usr/local/cuda-11.4/ with JetPack 5.
The compat folder is only needed when running on the platform with an older GPU driver.
For example, running CUDA 12 on the JetPack 5 which contains 11.4 GPU driver.
cuDNN INC/LIB can be found in the below (same as TensorRT):
