I want to know what is function of this code
Hi
i want to know what is function of this code?
v4l2-ctl -d /dev/video0 --set-fmt-video=width=1280,height=720,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count 100
Best
Is is for capturing raw frames through v4l2-ctl. You may buy a Raspberry Pi camera V2 and check how to connect it:
And run the command.
You may also try to capture through nvarguscamerasrc:
$ gst-launch-1.0 nvarguscamerasrc ! nvoverlaysink
This uses hardware ISP engine to process raw frames and output in YUV420.
