I want to run spa_all_to_all on Hots(x86)
I have switched the BF3 card to NIC mode and compiled the DPA_all_to_all sample on the Host (x86), but it fails to run. However, it runs correctly on the DPU (Arm). How can I run it on Host(X86)?
[11:49:59:952372][8632][DOCA][INF][dpa_all_to_all_core.c:2077][dpa_a2a] Number of processes = 8, message size = 32, message count = 1, buffer size = 8
[11:49:59:970465][8632][DOCA][ERR][linux_devx_adapter.cpp:154][send_prm_cmd] devx adapter 0x5a2a299326a0: Kernel failed to issue general PRM command=0x100, errno=EPROTONOSUPPORT (93)
[11:49:59:970480][8632][DOCA][ERR][device_adapter.cpp:109][query_hca_caps_by_opmod] Query devx HCA capabilities with op_mod=0x0 failed. err=DOCA_ERROR_DRIVER, syndrome=0x0
[11:49:59:970485][8632][DOCA][ERR][dpa_capabilities.cpp:78][doca_dpa_cap_is_supported] Failed to get devinfo capabilities
[11:49:59:970823][8634][DOCA][ERR][linux_devx_adapter.cpp:154][send_prm_cmd] devx adapter 0x5f456a5e80f0: Kernel failed to issue general PRM command=0x100, errno=EPROTONOSUPPORT (93)
[11:49:59:970845][8634][DOCA][ERR][device_adapter.cpp:109][query_hca_caps_by_opmod] Query devx HCA capabilities with op_mod=0x0 failed. err=DOCA_ERROR_DRIVER, syndrome=0x0
[11:49:59:970850][8634][DOCA][ERR][dpa_capabilities.cpp:78][doca_dpa_cap_is_supported] Failed to get devinfo capabilities
[11:49:59:972204][8637][DOCA][ERR][linux_devx_adapter.cpp:154][send_prm_cmd] devx adapter 0x5d3373516fc0: Kernel failed to issue general PRM command=0x100, errno=EPROTONOSUPPORT (93)
[11:49:59:972221][8637][DOCA][ERR][device_adapter.cpp:109][query_hca_caps_by_opmod] Query devx HCA capabilities with op_mod=0x0 failed. err=DOCA_ERROR_DRIVER, syndrome=0x0
[11:49:59:972225][8637][DOCA][ERR][dpa_capabilities.cpp:78][doca_dpa_cap_is_supported] Failed to get devinfo capabilities
[11:49:59:975478][8639][DOCA][ERR][linux_devx_adapter.cpp:154][send_prm_cmd] devx adapter 0x5cf7db743580: Kernel failed to issue general PRM command=0x100, errno=EPROTONOSUPPORT (93)
[11:49:59:975494][8639][DOCA][ERR][device_adapter.cpp:109][query_hca_caps_by_opmod] Query devx HCA capabilities with op_mod=0x0 failed. err=DOCA_ERROR_DRIVER, syndrome=0x0
[11:49:59:975499][8639][DOCA][ERR][dpa_capabilities.cpp:78][doca_dpa_cap_is_supported] Failed to get devinfo capabilities
The error “Kernel failed to issue general PRM command=0x100, errno=EPROTONOSUPPORT” typically indicates that the kernel or driver does not support the requested PRM command.
Please wait for the upcoming Doca-3.2 version which will be released at 25.10, this issue will be fixed.
