I want to run TAO training on background
currently I can execute to train to only running on Jupyter.
I am using the cv_sample_v1.2.0 tutorial.
How can I run the TAO train on background?
The command is below.
# Retraining using the pruned model as pretrained weights
!tao detectnet_v2 train -e $SPECS_DIR/detectnet_v2_retrain_resnet18_kitti.txt \
                        -r $USER_EXPERIMENT_DIR/experiment_dir_retrain \
                        -k $KEY \
                        -n resnet18_detector_pruned \
                        --gpus 4
Do you mean running in terminal instead of jupyter notebook?
Yes, it is possible.
Thank you for replying.
Could you tell me please.
is it the something commands?
The same as notebook.
In the terminal,
You can run
$ tao detectnet_v2 train xxx
Or you can also login the docker and then run training.
$ tao detectnet_v2 run /bin/bash
then,
# detectnet_v2 train xxx
thanks.
