I want to use TensorRT with Xavier. Xavier uses Jetpack 4.4.1, what is the compatible version of TensorRT? By the way, is the trained model of EfficientNet available in TensorRT?
you should type:
dpkg -l | grep TensorRT
Yes, you can. But you should convert (the ONNX model) to TensorRT model
