After secondary inference, metadata is stored and transmitted in various ways, but I am curious how the metadata is delivered to the tracker or secondary inference engine after primary inference
If i look at the config file, the second inference gets the id of the first inference, but I’m curious how to get the metadata in detail.
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
