I would like to debug TX1 on the board camera, such as the resolution of what, where to find his script file!
tx1上MIPI接口的板载摄像头,调试nvgstcapture-1.0
没有工程师回答下吗, 感觉资料好少, 文档都没有个。
Welcome to Jetson & Embedded Systems developer forum.
Please create the topic and issue in English manner.
Other developers can understand your issue and to share their experience with you quickly if they ever met similar issue in design stage.
And then other users could be leverage from this issue to get benefits.
Hi
You can check the GStreamer_User_Guide to find what you want. like below command.
gst-launch-1.0 nvcamerasrc fpsRange="30 30" ! 'video/xraw(memory:NVMM),
width=(int)1920, height=(int)1080,
format=(string)I420, framerate=(fraction)30/1' ! nvtee ! nvvidconv !
'video/x-raw(memory:NVMM), width=(int)640, height=(int)480,
format=(string)NV12’ ! omxh264enc ! qtmux ! filesink location=test.mp4
–e
Where can I find his driver, is some of the underlying source code
You can download the kernel source code from the download link. The TX1 reference camera sensor is ov5693, it locate …/kernel/drivers/media/i2c/ov5693.c
And nvidia did not release the source of the user space.
https://developer.nvidia.com/embedded/downloads
用TX1的我感觉大多数都是华人,反正感觉TX1的摄像头相关的东西就是云里雾里的,有ISP,但是不开放;例程只是针对不带ISP的sensor的,好晕晕!
那个板上的Camera就是个摆设!!!!!!!!!!!
