I am having a problem with I2C bus 7 timeout when I have the TX2 camera interface board installed and two Allied Vision Alvium cameras. With Jetpack 5.0.2 installed and the T2X interface connected I get I2c timeouts when I run sudo i2cdetect -y -r 7. If the board is removed then the scan runs fast and detects only the audio chip at x1A.
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: – – – – – – – – – – – – –
10: – – – – – – – – – – UU – – – – –
20: – – – – – – – – – – – – – – – –
30: – – – – – – – – – – – – – – – –
40: – – – – – – – – – – – – – – – –
50: – – – – – – – – – – – – – – – –
60: – – – – – – – – – – – – – – – –
70: – – – – – – – –
sudo dmesg | grep i2c
[ 3.154170] i2c /dev entries driver
[ 3.157506] tegra-i2c 3160000.i2c: Adding to iommu group 2
[ 3.163343] tegra-i2c c240000.i2c: Adding to iommu group 2
[ 3.168470] tegra-i2c 3180000.i2c: Adding to iommu group 2
[ 3.173825] tegra-i2c 3190000.i2c: Adding to iommu group 2
[ 3.179211] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[ 3.184826] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[ 3.190225] tegra-i2c c250000.i2c: Adding to iommu group 2
[ 6.998998] tegra-i2c 31e0000.i2c: Adding to iommu group 2
