I2C Connection Magnetometer
I am trying to get the MAG3110 Triple Axis Magnetometer to work with the jetson nano, through some python code. The first I am doing is seeing if the jetson will even detect it with the
i2cdetect
command and it does when I do
i2cdetect -y -r 1
Due to me connecting the SDA/SCl into the bus 1 ports. My output in the terminal gives me a 0e which is correct for the address that is for the Magnetometer (0x0e hexadecimal or 14 decimal).
I’m curious when I run simple commands in python from the smbus2 library such as
bus_i2c_block_data(14,0,32)
I get stuff that repeat and make no sense. I get a bunch of 0s followed by a 196, then 0s by 247 and this repeats.
When I hook the MAG3110 to an Arduino and run
#include <SparkFun_MAG3110.h>
MAG3110 mag = MAG3110(); //Instantiate MAG3110
void setup() {
  Serial.begin(9600);
  mag.initialize(); //Initializes the mag sensor
  mag.start();      //Puts the sensor in active mode
void loop() {
  int x, y, z;
  //Only read data when it's ready
  if(mag.dataReady()) {
    //Read the data
    mag.readMag(&x, &y, &z);
    Serial.print("X: ");
    Serial.print(x);
    Serial.print(", Y: ");
    Serial.print(y);
    Serial.print(", Z: ");
    Serial.println(z);
    Serial.println("--------");
It works like a charm.
Anyone run into the same problem with a MAG3110 or any i2c data reading problems?
Does i2cget get correct value?
Hi ShaneCCC,
If I do
i2cget -y 1 0x0E
I get
0x00
If I do
i2cget -y 1 0x0E 0x0E b
I get
0x00
If I do
i2cget -y 1 0x0E 0x0E w
I get
0xf900
Any kernel message while do the i2cget command?
No none
I think there no problem for the host, you may need consult with vendor what’s the correct way to access this device.
