Hi Sir,
In datasheet and ODM reference design guide,I2C_GP3_CLK is C12 and I2C_GP3_DAT is C13.
But in pinmux excel sheet, I2C_GP3_CLK is C13 and I2C_GP3_DAT is C12.
Which one is correct?
If pinmux excel sheet is wrong, how do I modify it to generate correct dtsi and cfg files?
PS: Currently I use this pinmux excel sheet (official release has the same conflict)
https://devtalk.nvidia.com/default/topic/1023417/jetson-tx2/pinmux-dts2cfg-py-gives-errors-from-default-pinmux/post/5208337/#5208337
hello JasonFan,
thanks for point out, we’ll check this internally.
hello JasonFan,
we had fix the erroneous, and we’ll update the spreadsheet from download center later.
thanks
Hi Jerry,
I found another problem for previous updated pinmux spreadsheet.
If I use the pinmux spreadsheet that you updated (no change), eth0 will be gone.
Please also check this.
Thank you.
eth0 is gone should be a big problem. any update?
Thank you
hello JasonFan,
we had revise the pinmux spreadsheet recently.
i would check the latest update version and get back to you.
thanks
hello JasonFan,
we had tested with the updated pinmux spreadsheet and the eth0 still works with TX2/R28.1
since you had file another new topic, https://devtalk.nvidia.com/default/topic/1025555
could you please share the steps to that topic, and let’s tracking there.
thanks
Hi JerryChang,
Thank you.
I have updated my steps on the topic.
