i2c timed out error tegra tk1
hi i have a jetson tk 1 board and i dont know what happened but it is struck on the bellow attached code. sometimes after a period it gets started but still the screen is blank
tegra-i2c tegra12-i2c.0: — register dump for debugging ----
tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[tegra-i2c tegra12-i2c.0: msg->len - 1
tegra-i2c tegra12-i2c.0: is_msg_write - 1
tegra-i2c tegra12-i2c.0: next_msg->len - 1
tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
tegra-i2c tegra12-i2c.0: buf_remaining - 1
tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x006b
Did you got the problem with the image from jetPack without any kernel modification?
