I2C8 / I2C_PM and EEPROM
I’m adapting the TX2i BSP for a custom carrier board, and in the pinmux spreadsheet, I disabled the pins for I2C8, also called I2C_PM, since our carrier board doesn’t use those pins. However, that caused the EEPROM with the MAC addresses to become unaccessible. But the EEPROM is supposed to be on I2C7, not I2C8. I’m concerned that there is a problem with the pinmux sheet. Can anyone explain why this happened?
Module EEPROM is using i2c8 but not i2c7. Where did you see eeprom is using i2c7?
