I have a few questions.
Now, first of all, I started using and learning jetson nano. I had a problem during the installation phase. Spidev files are supposed to exist but do not exist. I tried to install with pip3 by applying the solutions I found, but it is still not available and I get a different result in i2c detect. I followed the steps on this site Initial Setup | CircuitPython Libraries on Linux and the NVIDIA Jetson Nano | Adafruit Learning System.
I can’t continue my project.
-desktop:~$ sudo i2cdetect -y 1
[sudo] password for **:
Warning: Can’t use SMBus Quick Write command, will skip some addresses
0 1 2 3 4 5 6 7 8 9 a b c d e f
00:
10:
20:
30: – – – – – – – –
40:
50: – – – – – – – – – – – – – – – –
60:
70:
I am getting errors in my python codes. I keep getting errors even though the library is available. I’m using Spyder and it’s telling me to install ipykernel and cloudpickle. I installed it and when I do pip3 list I can see it but it still doesn’t work. What should I do?
I want to measure instantaneous temperature values in a simple way using MLX90614. Can anyone give code as an example?
Thank you from now.
