Hi everyone, i recently bought this i2s amp and im trying to connect it to my jetson nano
i hooked up everything and its working but the problem is i need my lrclk pin for something eles, is there a way i can use the amp without the lrclk pin?
im using only 1 amp(mono) and i dont mind if its only left or only right (maybe giving it a static current).
thank you
From a Jetson standpoint data will still be outputted on the DOUT but without the LRCLK the amp probably will not know where the start of the channel is and so I am doubtful this will work.
What do you need the LRCLK pin for if not for I2S?
I’m trying record and playback at the same time, but my recorder uses a different lrclk and different bclk, so they can’t work at the same time, is there a way a I can make a diffrend bclk and lrclk with other pins?
If the playback and capture devices require a different format, then you need to use different I2S interfaces. In other words, one for the playback device and one for the capture. Jetson Nano provides two I2S interfaces, the 2nd one is available on the M.2 connector which is not as easily accessible as the 40-pin header, but it is possible to use two I2S interfaces.
Do both playback and capture devices operate at the same sample rate and sample size but just differ in the number of channels? The I2S AMP does support TDM mode, does the capture device support TDM mode? In TDM mode there is just a single pulse to indicate the start of the frame but it does not indicate the number of channels. So it might be possible to use TDM mode, if both devices support it, but you would need to review the clock requirements of both devices.
First you need to check pinmux. The I2S3 pins are muxed on the dmic1/2 pins but by default they should be configured to I2S3. You can confirm by checking that bits [1:0] in the following registers are 0x1 for I2S3 …
