hi,
I find NX has one MCLK pin on 40-pin-header,
so what if you need to connect NX with two or more I2S devices?
In my case, I have a LT6911(a hdmi to mipi birdge IC) need to work on master mode and give MCLK to NX,
and I also need to connect NX with a CS4270(a audio codec) which works as a slave and need nx gives the MCLK.
So could NX work as a master for CS4270 and at the same time works as a slave for LT6911?
Could NX work well with above case?
I think this may be a general problem, is there any solutions to this case?
