Jon,
the aud_clk is now detached and has no parent clock (at the end of the list), are you sure that clk_pll_p_out1 is a valid clock shouldn’t it be clk_pll_p_out0?
Regards,
Igal
Jon,
Regards,
Igal
Hi Igal,
Yes that should be the one, but I see the following in the same file …
/* pll_p_out1 is not used for ahub for T210,T186 */
if (data->soc < TEGRA_ASOC_UTILS_SOC_TEGRA210) {
data->clk_pll_p_out1 = clk_get_sys(NULL, "pll_p_out1");
if (IS_ERR(data->clk_pll_p_out1)) {
dev_err(data->dev, "Can't retrieve clk pll_p_out1\n");
ret = PTR_ERR(data->clk_pll_p_out1);
goto err;
Can you remove this check on “if (data->soc < TEGRA_ASOC_UTILS_SOC_TEGRA210)”? The clock is defined in device-tree and so we should be able to use it.
Regards,
Jon
Jon, hi,
sorry but the function clk_get_sys fails.
Regards,
Igal
Hi Igal,
Yes of course, I did not catch that. Can you replace clk_get_sys() with tegra_alt_asoc_utils_get_clk(dev, false, “pll_p_out1”).
Regards,
Jon
Hi Igal,
Great, I assume that means you now have 12MHz output? I will fix the pllp clock request so this can be used as a clock parent in future releases for T210/T186.
Regards,
Jon
Jon,
Yes this means that I can see a clear 12[MHz] from J21 pin 7, thanks for the support.
Though, please don’t forget the bigger picture :) [url]TLV320AIC32x4 evaluation board with TX2 - Jetson TX2 - NVIDIA Developer Forums
Regards,
Igal
