I2S/TDM ADX Demux
Hi Chris,
Looking at the ADX driver I see it does a …
memset(adx->map, 0, sizeof(adx->map));
… and writes the entire map to the actual RAM map. So I believe you should not have to define any unused entries at the end of the frame.
Yes the ADX support S32_LE as well.
Cheers
Jon
Hi Jon,
Apologies. This is incorrect…
I can confirm that this does not work. It needs the unused entries which perhaps is a bug. I will debug the ADX driver when i get some time.
It does indeed work as described. My mistake was the adx-slot-size being incorrect.
Thanks for your time, Jon. Once i have finally tidied everything up i will share all the drivers etc.
Regards,
Chris
Hi Chris,
Thanks for confirming!
Regards,
Jon
