When I run the ibdiagnet utility expecting to dump some port counters, the output seems to be going to a file. Can someone please point me to the details on how to retrieve this output file?
Also, is there a way to run this command only for a given port, as I am interested only in a specific module plugged into a specific port?
switch-## [standalone: master] (config) # ibdiagnet -P all
ibdiagnet output files were archived into ibdiagnet_output.tgz
If you require further assistance, please feel free to open a case with us through the support portal and we’ll be more than happy to assist you further in detail.
I was able to FTP into the switch but encountered a permission issue, even though I am supposed to have admin permissions. After login, the default working directory is /var/home/root, and I can’t access the desired directory.
I also tried to direct the ibdiagnet output to a directory that I can access, but it did not allow me to do so.
switch-## [standalone: master] (config) # ibdiagnet --output_path /var/home/root % ibdiagnet -o flag is not allowed switch-## [standalone: master] (config) #
Any thoughts on how to solve this permission issue or get around it? Appreciate any help.
