We are using centos7 and Mellanox ConnectX-5.
We are trying to use ibdump from ibdump-6.0.0-1.50100.0.x86_64.rpm
This is the log…
ibdump
Initiating resources …
searching for IB devices in host
Port active_mtu=1024
MR was registered with addr=0x1648010, lkey=0xafc0, rkey=0xafc0, flags=0x1
Device : “mlx5_0”
Physical port : 1
Link layer : Ethernet
Dump file : sniffer.pcap
Sniffer WQEs (max burst size) : 4096
Failed to set port sniffer1: command interface bad param
ethtool from mlnx-ethtool-5.4-1.50100.0.x86_64.rpm
I then obtained ethtool from mellanox site and
tried to run this command
ethtool --set-priv-flags enp130s0f0 sniffer on
I get
ethtool: bad command line argument(s)
For more information run ethtool -h
How do I run ibdump with connectx-5 successfully?
Hello Sainath,
Thank you for posting your inquiry to the Mellanox Community.
We see that your organization currently has a valid support contract with Mellanox.
As such, we’ve opened a Mellanox support ticket on your behalf.
We will continue to track this issue via our support portal, and will provide further information to you directly.
Thank you,
Mellanox Technical Support
HI Sainath,
Have you sloved this problem? I have the same problem with you. That is “Failed to set port sniffer1: command interface bad param”, i don’t know how to deal with it. If you know the answer, please share with me. Thank you a lot.😁
Hello Sainath,
MR was registered with addr=0x22ca650, lkey=0x862f, rkey=0x862f, flags=0x1
Device : “mlx5_1”
Physical port : 1
i don’t know how to solve it.if you solve this problem,please share the answer with me,thank you
