IBIS Model Jetson Xavier
Trying to run PCIe simulation using IBIS model and getting this error:
“#### SPISim’s AMI Model has expired. Simulation aborted!! ####”** *see inside the AMI file line 18
Can you help me figure it out?
Thank you,
Hi, we are checking this, there will be a new version package released once available.
Thank you for your answer,
Is there a target date?
We are in the middle of the PCB layout and want to minimize risks,
Efi
No ETA yet.
The layout quality can be guaranteed by layout guideline in OEM DG, if you follow that well there should be no problem. Also you can refer to the pcb file of dev kit as reference example.
