In my example, I use RDMA CM to connect nodes and deal with the connection in RDMA_CM_EVENT_ESTABLISHED.
here is my server’s code:
void on_connected(struct rdma_cm_id *id, struct resources *res){
struct ibv_cq *cq=res->cq;
struct ibv_wc wc;
while(1){
int numx=ibv_poll_cq(res->recv_cq,1,&wc);
if (numx=0){
continue;
if(numx<0){
std::cout << "error" << std::endl;
if(wc.status==IBV_WC_SUCCESS){
if(wc.opcode==IBV_WC_SEND){
std::cout << "send completed" << std::endl;
if(wc.opcode==IBV_WC_RECV){
// rdma_post_recv(id,NULL,res->buf,kMemSize,res->mr);
std::cout << "recv completed mem in server: " << res->buf << std::endl;
std::string data = "server server!";
memcpy(res->buf, data.c_str(), data.size());
std::cout << "mem in server: " << res->buf << std::endl;
break;
std::cout << "once again" << std::endl;
rdma_post_send(id,NULL,res->buf,kMemSize,res->mr,0);
In my client’s code, I only call ibv_post_send()
once.
I think when I call ibv_poll_cq()
one CQE will pop out. In my case, there will be no CQE in CQ. But I can always get one actuality. Is there some wrong when I use the API?
Thanks for your answers.
I’m not sure whether I set the signaled flag. Here is my part of the code for the client.
struct ibv_send_wr sr;
struct ibv_sge sge;
struct ibv_send_wr *bad_wr = nullptr;
struct ibv_wc wc;
std::string data = "client client!";
std::cout << "mem in client: " << res->buf << std::endl;
memset(&sge, 0, sizeof(sge));
sge.addr = (uintptr_t) res->buf;
sge.length = kMemSize;
sge.lkey = res->mr->lkey;
memset(&sr, 0, sizeof(sr));
sr.next = nullptr;
sr.wr_id = (uintptr_t)id->context;
sr.sg_list = &sge;
sr.num_sge = 1;
sr.opcode = IBV_WR_SEND;
sr.send_flags = IBV_SEND_SIGNALED;
ibv_post_send(res->qp, &sr, &bad_wr);
std::cout << "send" << std::endl;
while (1) {
int num_wc = ibv_poll_cq(res->recv_cq, 1, &wc);
if (num_wc < 0) {
std::cout << num_wc << " poll error!" << std::endl;
if (wc.status != IBV_WC_SUCCESS) {
std::cout << "error!" << std::endl;
if ( wc.opcode == IBV_WC_RECV ) {
break;
For now, I have not considered the error case. I will catch it and handle it.
Sorry for that. It’s just a comment. It’s meanless. Sorry to confuse you.
Yes, when the client handle RDMA_CM_EVENT_ADDR_RESOLVED, I call ibv_post_recv()
. I think it is OK, right?
system
Closed
April 24, 2023, 10:28am
4
