ICC is not compatible with CUDA on VS2010.
I wanna run ICC&CUDA hybrid code on VS2010.(due to MKL,IPP)
But If I change visual c++ to Intel c++, MSB3721 error is occured.
And if I change visual c++ to Intel c++ after build with visual c++, the error is not occured.
I think that it’s look like a compiler path error.
What should I do fix this error?
(I’ve already done latest updating for CUDA(4.2)&ICC.)
Use nvcc to generate C source files, then feed those to the intel compiler.
http://forums.nvidia.com/index.php?showtopic=153975
