ICE: Lowering Error: allocate with no array size
Hi, I’ve just faced this issue that is not critical, but kind of interesting to me because the SUM intrinsic is involved (if I replace the SUM intrinsic or if I uncomment the subroutine, it builds fine).
So, the following program hangs the compiler:
program bug_contains
implicit none
integer :: y
integer, parameter  ::  dx = 32
integer, parameter  ::  dy = 32
integer :: A(dx)
integer :: B(dx,dy)
B = 0.
A(:) = SUM(B(:,:), dim=2)
!this line causes the issue, when building with -fast, -O2 or -O3
contains
!uncommenting this subroutine eliminates the issue
!subroutine dummy(B)
!  integer :: B
!  B=0
!end subroutine
end program
The compiler shows the message below before hanging:
Lowering Error: allocate with no array size [ast=76,asttype=38,datatype=0]
Tested with nvfortran 24.3.
Thank Rommel. Definitely an interesting corner case in that it seems to only occur with 2D fixed sized arrays in a SUM intrinsic when dim=2, and there’s an empty contains statement.
I added a report, TPR#35797 and sent it to engineering.
