Hi!
I am getting the following error:
PGF90-F-0000-Internal compiler error. interf:new_symbol, symbol not found 625
I narrowed the source of the problem when there is an ENTRY statement from one module used in another.
This error can be reproduced with the following simple code:
File a_mod.f90
module a_mod
use iso_fortran_env
implicit none
private
public :: test, entr
integer(kind=int32) ,public ,parameter :: a1=30
contains
subroutine test(a)
implicit none
integer(kind=int32) ,intent(in) :: a
integer(kind=int32) :: ee
print*,"sub out:",a + a1
return
entry entr(ee)
print*,"entry: ", ee
end subroutine test
end module a_mod
File b_mod.f90
module b_mod
use a_mod, only: a1,test,entr
end module b_mod
File prog.f90
program prog
use iso_fortran_env
use b_mod, only: test, a1
implicit none
print*, b1
end program prog
Here is the output of the commands:
% pgfortran -c a_mod.f90 b_mod.f90
a_mod.f90:
b_mod.f90:
% pgfortran -o prog prog.f90 a_mod.o b_mod.o
prog.f90:
PGF90-F-0000-Internal compiler error. interf:new_symbol, symbol not found 625 (prog.f90: 4)
PGF90/x86-64 Linux 18.10-1: compilation aborted
This error does not occur when I use Intel or Cray Fortran compilers.
Do you have a workaround?
Could you make pgfortran compatible with this behavior?
Thanks for your help!
Hect0r
