I want to turn tx off by replacing qsfp28’s tx_disable with 1.
Is there a possible way?
[root@SNIPER ~]# mlxcables -d mt4119_pciconf0_cable_0 --read_reg TX_disable
TX_disable = 0x00
[root@SNIPER ~]# ethtool -i eth2
driver: mlx5_core
version: 4.7-1.0.0
firmware-version: 16.26.1040 (MT_0000000010)
expansion-rom-version:
bus-info: 0000:3b:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: no
supports-register-dump: no
supports-priv-flags: yes
root@SNIPER ~]# ethtool -m eth2
Identifier : 0x11 (QSFP28)
Extended identifier : 0xcc
Extended identifier description : 3.5W max. Power consumption
Extended identifier description : CDR present in TX, CDR present in RX
Extended identifier description : High Power Class (> 3.5 W) not enabled
Connector : 0x07 (LC)
Transceiver codes : 0x80 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Transceiver type : 100G Ethernet: 100G Base-LR4
Encoding : 0x05 (64B/66B)
BR, Nominal : 25500Mbps
Rate identifier : 0x00
Length (SMF,km) : 10km
Length (OM3 50um) : 0m
Length (OM2 50um) : 0m
Length (OM1 62.5um) : 0m
Length (Copper or Active cable) : 0m
Transmitter technology : 0x40 (1310 nm DFB)
Laser wavelength : 1302.350nm
Laser wavelength tolerance : 1.030nm
Vendor name : FS
Vendor OUI : 00:02:c9
Vendor PN : QSFP28-LR4-100G
