I’m working on integerized implementation of a neural network. Goal is to have identical behavior across platforms and also for CPU/GPU. Which to the best of my knowledge can only be done with integer operations. This is only needed for inference.
I’ve been studying the cudNN API, especially API Reference :: NVIDIA Deep Learning cuDNN Documentation
I believe the only way to do what I want is to use the INT8_CONFIG. This means GPU should support DP4A. Am I correct so far? Or are there other issues that will stand in the way of integer only operations on GPU?
Where can I find list of GPUs that support DP4A? My current GPU is a TITAN RTX, I believe it does not support this.
Thanks in advance!
