If conditional both true-graph and false-graph are executed
Description
Use if condition in onnx, but both true-graph and false-graph are executed.
python script generate onnx file:
modify_onnx_simp.txt (5.5 KB)
import time
import onnx
import queue
import onnxsim
import numpy as np
import onnxruntime as ort
import onnx_graphsurgeon as gs
def two_matmul():
    batch_size, num_output_feat = 300, 8096
    num_input_1_feat, num_input_2_feat = 1024, 4096
    dst_onnx_path = 'two_matmul.onnx'
    # matmul node 1
    input_1 = gs.Variable(
            name='input_1',
            dtype=np.float32,
            shape=(batch_size, num_input_1_feat)
    matmul_1_weight = gs.Constant(
            name=f'matmul_1_weight',
            values=np.random.rand(num_input_1_feat, num_output_feat).astype(np.float32)
    matmul_1_output = gs.Variable(
            name='matmul_1_output',
            dtype=np.float32,
            shape=(batch_size, num_output_feat)
    matmul_node_1 = gs.Node(
            op='MatMul',
            name='MatMul_1',
            inputs=[input_1, matmul_1_weight],
            outputs=[matmul_1_output]
    # matmul node 2
    input_2 = gs.Variable(
            name='input_2',
            dtype=np.float32,
            shape=(batch_size, num_input_2_feat)
    matmul_2_weight = gs.Constant(
            name=f'matmul_2_weight',
            values=np.random.rand(num_input_2_feat, num_output_feat).astype(np.float32)
    matmul_2_output = gs.Variable(
            name='matmul_2_output',
            dtype=np.float32,
    matmul_node_2 = gs.Node(
            op='MatMul',
            name='MatMul_2',
            inputs=[input_2, matmul_2_weight],
            outputs=[matmul_2_output]
    graph = gs.Graph(
            nodes=[matmul_node_1, matmul_node_2],
            inputs=[input_1, input_2],
            outputs=[matmul_1_output, matmul_2_output],
            name='two_matmul',
            opset=11
    dst_onnx_model = gs.export_onnx(graph)
    dst_onnx_model= onnx.shape_inference.infer_shapes(dst_onnx_model, data_prop=True)
    onnx.checker.check_model(dst_onnx_model)
    onnx.save(dst_onnx_model, dst_onnx_path)
def two_matmul_if():
    dst_onnx_path = 'two_matmul_if.onnx'
    # matmul node(branch) 1
            name='input_1',
            dtype=np.float32,
            dtype=np.float32,
            op='MatMul',
            name='MatMul_1',
    subgraph_1 = gs.Graph(
            nodes=[matmul_node_1],
            inputs=[input_1],
            outputs=[matmul_1_output],
            name='subgraph_1',
            opset=13
    # matmul node(branch) 2
            name='input_2',
            dtype=np.float32,
            dtype=np.float32,
            op='MatMul',
            name='MatMul_2',
    subgraph_2 = gs.Graph(
            nodes=[matmul_node_2],
            inputs=[input_2],
            outputs=[matmul_2_output],
            name='subgraph_2',
            opset=13
    # equal node
    input_flag = gs.Variable(
            name='input_flag',
            dtype=np.int32,
            shape=()
    equal_target = gs.Constant(
            name=f'Equal_target',
            values=np.array(1, dtype=np.int32)
            # values=np.array([0], dtype=np.int32).reshape((1, ))
    equal_output = gs.Variable(
            name='equal_output',
            dtype=np.bool_,
            shape=()
    equal_node = gs.Node(
            op='Equal',
            name='Equal',
            inputs=[input_flag, equal_target],
            outputs=[equal_output]
    # if node
    if_output = gs.Variable(
            name='if_output',
            dtype=np.float32,
    if_node = gs.Node(
            op='If',
            name='If',
            attrs={'then_branch': subgraph_1, 'else_branch': subgraph_2},
            inputs=[equal_output],
            outputs=[if_output]
    # total graph
    graph = gs.Graph(
            nodes=[equal_node, if_node],
            inputs=[input_1, input_2, input_flag],
            outputs=[if_output],
            name='two_matmul_if',
            opset=13
if __name__ == '__main__':
    two_matmul()
    two_matmul_if()
Environment
TensorRT Version: 10.2.0
GPU Type: A30
Nvidia Driver Version: 470.57.02
CUDA Version: 11.4
CUDNN Version:
Operating System + Version: centos7
Python Version (if applicable):
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Steps To Reproduce
generate onnx model two_matmul_if.onnx
python3 modify_onnx_simp.py
generate two_matmul_if.engine
trtexec --builderOptimizationLevel=3 --maxAuxStreams=0 --useCudaGraph --onnx=two_matmul_if.onnx --saveEngine=two_matmul_if.engine
generate flag input
np.array([0], dtype=np.int32).reshape((1, )).tofile('flag_0.bin')
np.array([1], dtype=np.int32).reshape((1, )).tofile('flag_1.bin')
profile engine with flag_0.bin, expect true-branch(MatMul_1) run.
/trtexec --warmUp=100  --iterations=10000 --useCudaGraph  --separateProfileRun  --dumpProfile --useSpinWait --noDataTransfers --loadEngine=two_matmul_if.engine --loadInputs='input_flag':flag_0.bin
profile engine with flag_1.bin, expect false-branch(MatMul_2) run.
/trtexec --warmUp=100  --iterations=10000 --useCudaGraph  --separateProfileRun  --dumpProfile --useSpinWait --noDataTransfers --loadEngine=two_matmul_if.engine --loadInputs='input_flag':flag_1.bin
input flag_0.bin and flag_1.bin profile is same, both MatMul_1 and MatMul_2 run.
[07/15/2024-20:17:13] [I]    Time(ms)     Avg.(ms)   Median(ms)   Time(%)   Layer
[07/15/2024-20:17:13] [I]       23.00       0.0023       0.0022       0.3   __mye186_hc_init_myl0_0
[07/15/2024-20:17:13] [I]     1313.88       0.1301       0.1297      18.1   MatMul_1_myl0_1
[07/15/2024-20:17:13] [I]     5517.65       0.5462       0.5486      76.1   MatMul_2_myl0_2
[07/15/2024-20:17:13] [I]      140.25       0.0139       0.0129       1.9   copy_d2h___mye161_myl0_3
[07/15/2024-20:17:13] [I]       23.69       0.0023       0.0023       0.3   __mye33cbr_myl0_4
[07/15/2024-20:17:13] [I]      211.70       0.0210       0.0208       2.9   __myl_Mov_myl0_5
[07/15/2024-20:17:13] [I]       22.79       0.0023       0.0022       0.3   jmp__mye39_myl0_6
[07/15/2024-20:17:13] [I]     7252.96       0.7180       0.7177     100.0   Total
Please include:
  • Exact steps/commands to build your repro
  • Exact steps/commands to run your repro
  • Full traceback of errors encountered
