I have nvidia igx system - NVIDIA IGX Platform,
This system was working good until today as we are not able to display anything from the system though it booting up.
I checked by going to bootable mode, there are lot of options in boot manager, please can you guide me how to boot in safe way and get back the system to working state.
I’m not sure which release is present, we are not getting the output/display on the monitor to confirm on that. (I’m getting - “NO DP signal from your device”)
Please can you tell me how to get the uart log, I can share them here.
Having Ubuntu 18.04 version, we were able to initiate the re-flash as it enable the Holopack DP 2.0.
Its taking more time than expected, we restarted more than 3 times for installation and re-flash. (attached screenshot)
DP1.0 as mentioned above in this thread is not available while re-flashing.
What are these difference between holopack DP 2.0, and DP 1.0 that you have mentioned in this thread.
You can refer to Installing Holopack (deprecated) - NVIDIA Docs for the difference.
“Software Stack on IGX has moved to IGX-SW. Holopack on IGX is now deprecated. It is recommended to move from Holopack to IGX-SW. Read the Software Releases Section of this guide for more on IGX-SW.”
It seems they are both deprecated.
Since the Ethernet cable is connected from host system to IGX system we will not be able to provide internet right, So we have given WIFI network access to both IGX and Host system.
There would be 2 ethernet port on IGX devkit.
You can connect the left one to the internet, and connect the right one on your host for BMC.
Please do not use SDKM for IGX from IGX SW 1.0 Production release.
All the steps and required procedures to install/setup IGX are in the link I shared above.
