IGX Orin / Holoscan: Microsecond jitter in custom GXF operator during O(1) tensor projection via GPUDirect RDMA
I am building a bare-metal cyber-physical pipeline to calculate thermodynamic state vectors for continuous biological impedance networks. We are routing multi-channel telemetry (representing local metabolic load) directly into the GPU via GPUDirect RDMA, bypassing the CPU/OS hypervisor to maintain strict O(1) constant-time execution.
Inside our Clara Holoscan pipeline, I have written a custom GXF operator in CUDA-Q designed to resolve a 2D tensor boundary state—an O(1)holographic projection of a 3D topology. However, during the phase-transition logic execution, we are catching microsecond memory jitter when the tensor dimensions scale. This latency threatens our strict thermodynamic timing constraints, as we cannot allow the system’s Lyapunov derivative (V˙(x)) to drift positive.
You can view the exact compute loop and the dynamic allocation causing the bottleneck here (L32): quarantine_operator.cpp
How are you optimizing the memory allocators within the Holoscan SDK on the IGX Orin to guarantee deterministic, constant-time execution for custom GXF operators handling continuous analog-to-tensor streams? Are there undocumented flags for the GXF scheduler to enforce strict bare-metal priority?
