IGX Thor devkit (T7000) Type-C issue
Hi NV,
I am currently using the IGX Thor Devkit (T7000) with the firmware and ISO downloaded from the IGX Download Center. The flashing process completed successfully, and I did not encounter any issues during installation.
However, during peripheral I/O testing, I noticed that the USB Type-C port is not functioning correctly. Although the connected USB hub receives power (its LED indicator turns on), no USB devices are detected, and no data transfer occurs. I have tested multiple devices, including USB flash drives, keyboards, and mice, and none of them are recognized when connected via the Type-C port.
Thanks!!
Hi SamM11,
What’s the IGX-SW release you are using? 2.0 Production Release?
There’s only one USB-C port on IGX Thor developer kit.
What’s your current use case for USB-C?
Could you share the result of lsusb at this moment?
Hi @KevinFFF ,
Thanks for reply.
→ Yes, I follow the IGX Download Center to download IGX OS ISO.
There’s only one USB-C port on IGX Thor developer kit. What’s your current use case for USB-C?
→ My current use case is fairly simple. I just want to connect a USB hub or access USB storage devices through the USB Type-C port.
I’m currently using a USB Type-C to USB Type-A adapter to connect the devices. The USB hub receives power (its LED turns on), but no data communication is established. I’ve also tested with native USB Type-C devices, and they are not detected either. As a result, neither USB storage devices nor USB keyboards/mice can be used through the Type-C port.
Could you share the result of at this moment? $ lsusb
→ $ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 0424:4206 Microchip Technology, Inc. (formerly SMSC) USB4206 Smart Hub
Bus 001 Device 003: ID 0424:4206 Microchip Technology, Inc. (formerly SMSC) USB4206 Smart Hub
Bus 001 Device 004: ID 13d3:3586 IMC Networks Bluetooth Radio
Bus 001 Device 005: ID 0424:724a Microchip Technology, Inc. (formerly SMSC) USB2 Controller Hub
Bus 001 Device 006: ID 0424:724a Microchip Technology, Inc. (formerly SMSC) USB2 Controller Hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 002: ID 0424:7206 Microchip Technology, Inc. (formerly SMSC) USB7206 Smart Hub
Bus 002 Device 003: ID 0424:7206 Microchip Technology, Inc. (formerly SMSC) USB7206 Smart Hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 1d6b:0107 Linux Foundation USB Virtual Hub
Bus 003 Device 003: ID 0525:a4a2 Netchip Technology, Inc. Linux-USB Ethernet/RNDIS Gadget
Thanks!!
On IGX Thor devkit T7000, the current USB Type-C port software does not support USB host mode yet.
At this moment, that port is intended for flashing/debug use, so USB storage, hubs, keyboard, and mouse connected through the Type-C port will not enumerate.
The behavior you observed in lsusb is therefore expected with the current software.
Please use the regular USB host ports(i.e. 4 USB-A ports) for USB peripherals for now.
Hi @KevinFFF ,
Thanks for reply.
Does the board kit have the same issue as well?
Thanks!!
There’s no difference for USB-C between the developer kit and the board kit.
