Hi @KevinFFF ,
Thanks for reply,
IGX OS : IGX OS 2.0 download from [Link]
- Firmwares
- BMC Firmware (v5.4)
- MCU Firmware (V2.00.02)
- Boot Firmware (QSPI) (R38.5.0-2026.03-11)
The closest known issue in IGX-SW 2.0 is a case where Wi-Fi may fail to enumerate after SC7 suspend/resume, and the suggested workaround is a hard reset: IGX-SW 2.0 Production Release — NVIDIA IGX Developer Guide.
→ Thanks for pointing that out. I was already aware of this known issue, so I removed the suspend operation in advance and have not been using suspend/resume for the related tests.
Your case looks slightly different since it happens after reboot with LAN connected. Please share , , , and from both a good boot and a bad boot, along with your IGX OS / BSP / firmware versions.lspcidmesg | grep -i -E "pcie|wifi|rtl|8852|enumer"nmcli device statusrfkill list
As a quick check, please try a full hard reset / power cycle and see whether Wi-Fi comes back.
Currently, I have both an IGX Thor DevKit and a Board Kit. I believe they are essentially the same platform, but I have reproduced the issue on both of them.
At the moment, the workaround is to completely power off the system and then power it back on. As you mentioned, performing a full hard reset / power cycle can recover the Wi-Fi functionality and resolve the current situation.
However, I don’t think this would be an acceptable solution for customers as a long-term workaround, since they would need to completely power-cycle the system whenever the issue occurs.
Good boot:
Devkit:
$ sudo lspci
0000:00:00.0 PCI bridge: NVIDIA Corporation Device 22e6
0000:01:00.0 3D controller: NVIDIA Corporation Device 2b00 (rev a1)
0001:00:00.0 PCI bridge: NVIDIA Corporation Device 22d8
0001:01:00.0 PCI bridge: Pericom Semiconductor PI7C9X2G608GP PCIe2 6-Port/8-Lane Packet Switch
0001:02:01.0 PCI bridge: Pericom Semiconductor PI7C9X2G608GP PCIe2 6-Port/8-Lane Packet Switch
0001:02:02.0 PCI bridge: Pericom Semiconductor PI7C9X2G608GP PCIe2 6-Port/8-Lane Packet Switch
0001:02:03.0 PCI bridge: Pericom Semiconductor PI7C9X2G608GP PCIe2 6-Port/8-Lane Packet Switch
0001:02:04.0 PCI bridge: Pericom Semiconductor PI7C9X2G608GP PCIe2 6-Port/8-Lane Packet Switch
0001:02:05.0 PCI bridge: Pericom Semiconductor PI7C9X2G608GP PCIe2 6-Port/8-Lane Packet Switch
0001:03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller (rev 1b)
0001:35:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller (rev 1b)
0001:67:00.0 Serial controller: Nanjing Qinheng Microelectronics Co., Ltd. Device 3450 (rev 10)
0001:99:00.0 PCI bridge: ASPEED Technology, Inc. AST1150 PCI-to-PCI Bridge (rev 06)
0001:9a:00.0 VGA compatible controller: ASPEED Technology, Inc. ASPEED Graphics Family (rev 52)
0001:9a:02.0 USB controller: ASPEED Technology, Inc. Device 2603
0001:cb:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8852CE PCIe 802.11ax Wireless Network Controller (rev 01)
0002:00:00.0 PCI bridge: NVIDIA Corporation Device 22d8
0002:01:00.0 Non-Volatile memory controller: Sandisk Corp WD PC SN5000S M.2 2280 NVMe SSD (DRAM-less)
0003:00:00.0 PCI bridge: NVIDIA Corporation Device 22da
0003:01:00.0 SATA controller: Marvell Technology Group Ltd. 88SE9235 PCIe 2.0 x2 4-port SATA 6 Gb/s Controller (rev 11)
0004:00:00.0 PCI bridge: NVIDIA Corporation Device 22d6
0004:01:00.0 PCI bridge: Mellanox Technologies MT2910 Family [ConnectX-7 PCIe Bridge]
0004:02:00.0 PCI bridge: Mellanox Technologies MT2910 Family [ConnectX-7 PCIe Bridge]
0004:02:01.0 PCI bridge: Mellanox Technologies MT2910 Family [ConnectX-7 PCIe Bridge]
0004:02:02.0 PCI bridge: Mellanox Technologies MT2910 Family [ConnectX-7 PCIe Bridge]
0004:03:00.0 Ethernet controller: Mellanox Technologies MT2910 Family [ConnectX-7]
0004:03:00.1 Ethernet controller: Mellanox Technologies MT2910 Family [ConnectX-7]
0004:04:00.0 PCI bridge: Mellanox Technologies MT2910 Family [ConnectX-7 PCIe Bridge]
0004:05:08.0 PCI bridge: Mellanox Technologies MT2910 Family [ConnectX-7 PCIe Bridge]
0004:07:00.0 PCI bridge: Mellanox Technologies MT2910 Family [ConnectX-7 PCIe Bridge]
0004:08:00.0 PCI bridge: Mellanox Technologies MT2910 Family [ConnectX-7 PCIe Bridge]
0004:09:00.0 VGA compatible controller: NVIDIA Corporation Device 2bb4 (rev a1)
0004:09:00.1 Audio device: NVIDIA Corporation Device 22e8 (rev a1)
$ sudo dmesg | grep -i -E "pcie|wifi|rtl|8852|enumer"
[ 0.000000] [TS:44051606917] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.8.0-1019-nvidia-tegra-rt root=UUID=695df0ed-0ea3-49d6-9fde-386c7985ed34 ro mminit_loglevel=4 preempt=full earlycon=tegra_utc,mmio32,0xc5a0000 video=efifb:off console=tty0 console=ttyUTC0,115200 clk_ignore_unused firmware_class.path=/etc/firmware fbcon=map:0 nospectre_bhb efi=runtime bl_prof_dataptr=6225920@0x2008010000 bl_prof_ro_ptr=65536@0x20 pci=pcie_bus_safe rd.driver.blacklist=nouveau nouveau.modeset=0 console=tty0 console=ttyUTC0,115200
[ 4.861774] [TS:49141311184] pci-host-generic d0b0000000.pcie: host bridge /bus@0/pcie@d0b0000000 ranges:
[ 4.861793] [TS:49141329777] pci-host-generic d0b0000000.pcie: MEM 0x0020000000..0x0027ffffff -> 0x0020000000
[ 4.861797] [TS:49141334712] pci-host-generic d0b0000000.pcie: MEM 0xd0c0000000..0xd87fffffff -> 0xd0c0000000
[ 4.861800] [TS:49141337258] pci-host-generic d0b0000000.pcie: IO 0xd084000000..0xd0841fffff -> 0x0084000000
[ 4.861831] [TS:49141368666] pci-host-generic d0b0000000.pcie: ECAM at [mem 0xd0b0000000-0xd0bfffffff] for [bus 00-ff]
[ 4.963278] [TS:49242815666] pci-host-generic d0b0000000.pcie: PCI host bridge to bus 0000:00
[ 4.963318] [TS:49242855101] pci 0000:00:00.0: [10de:22e6] type 01 class 0x060400 PCIe Root Port
[ 4.964733] [TS:49244270536] pci 0000:01:00.0: [10de:2b00] type 00 class 0x030200 PCIe Endpoint
[ 4.965332] [TS:49244869194] pci 0000:01:00.0: 0.000 Gb/s available PCIe bandwidth, limited by Unknown x0 link at 0000:00:00.0 (capable of 32.000 Gb/s with 2.5 GT/s PCIe x16 link)
[ 4.972412] [TS:49251949684] pcieport 0000:00:00.0: Adding to iommu group 0
[ 4.973200] [TS:49252736805] pcieport 0000:00:00.0: PME: Signaling with IRQ 123
[ 4.973964] [TS:49253501064] pcieport 0000:00:00.0: AER: enabled with IRQ 125
[ 6.342003] [TS:50621539888] pcie_tegra264: loading out-of-tree module taints kernel.
[ 6.342568] [TS:50622105092] tegra264-pcie a808400000.pcie: host bridge /bus@0/pcie@a808400000 ranges:
[ 6.342587] [TS:50622124036] tegra264-pcie a808400000.pcie: MEM 0x0028000000..0x002bffffff -> 0x0028000000
[ 6.342598] [TS:50622135573] tegra264-pcie a808400000.pcie: MEM 0x002c000000..0x002fffffff -> 0x002c000000
[ 6.342605] [TS:50622142342] tegra264-pcie a808400000.pcie: MEM 0xa8c0000000..0xb07fffffff -> 0xa8c0000000
[ 6.342610] [TS:50622147304] tegra264-pcie a808400000.pcie: IO 0xa884000000..0xa8841fffff -> 0x0084000000
[ 6.342719] [TS:50622256369] tegra264-pcie a808400000.pcie: ECAM at [mem 0xa8b0000000-0xa8bfffffff] for [bus 00-ff]
[ 6.451121] [TS:50730658629] tegra264-pcie a808400000.pcie: PCIe Controller-1 Link is UP (Speed: 2)
[ 6.451275] [TS:50730812221] tegra264-pcie a808400000.pcie: PCI host bridge to bus 0001:00
[ 6.451343] [TS:50730880036] pci 0001:00:00.0: [10de:22d8] type 01 class 0x060400 PCIe Root Port
[ 6.643398] [TS:50922935240] pci 0001:01:00.0: [12d8:2608] type 01 class 0x060400 PCIe Switch Upstream Port
[ 6.645383] [TS:50924920564] pci 0001:02:01.0: [12d8:2608] type 01 class 0x060400 PCIe Switch Downstream Port
[ 6.646123] [TS:50925659869] pci 0001:02:02.0: [12d8:2608] type 01 class 0x060400 PCIe Switch Downstream Port
[ 6.646817] [TS:50926354462] pci 0001:02:03.0: [12d8:2608] type 01 class 0x060400 PCIe Switch Downstream Port
[ 6.647565] [TS:50927102341] pci 0001:02:04.0: [12d8:2608] type 01 class 0x060400 PCIe Switch Downstream Port
[ 6.648282] [TS:50927819064] pci 0001:02:05.0: [12d8:2608] type 01 class 0x060400 PCIe Switch Downstream Port
[ 6.650878] [TS:50930414832] pci 0001:03:00.0: [10ec:8168] type 00 class 0x020000 PCIe Endpoint
[ 6.652252] [TS:50931789591] pci 0001:35:00.0: [10ec:8168] type 00 class 0x020000 PCIe Endpoint
[ 6.653248] [TS:50932785490] pci 0001:67:00.0: [1c00:3450] type 00 class 0x070005 PCIe Legacy Endpoint
[ 6.654078] [TS:50933614795] pci 0001:99:00.0: [1a03:1150] type 01 class 0x060400 PCIe to PCI/PCI-X bridge
[ 6.657818] [TS:50937355249] pci 0001:cb:00.0: [10ec:c852] type 00 class 0x028000 PCIe Endpoint
[ 6.677403] [TS:50956939814] pcieport 0001:00:00.0: Adding to iommu group 13
[ 6.678373] [TS:50957909795] pcieport 0001:00:00.0: PME: Signaling with IRQ 168
[ 6.678907] [TS:50958443953] pcieport 0001:00:00.0: AER: enabled with IRQ 155
[ 6.679375] [TS:50958912008] pcieport 0001:00:00.0: DPC: enabled with IRQ 154
[ 6.679378] [TS:50958914897] pcieport 0001:00:00.0: DPC: error containment capabilities: Int Msg #1, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 6.704158] [TS:50983695091] pcieport 0001:01:00.0: Adding to iommu group 14
[ 6.704308] [TS:50983845397] pcieport 0001:01:00.0: enabling device (0000 -> 0003)
[ 6.723145] [TS:51002682073] pcieport 0001:02:01.0: Adding to iommu group 15
[ 6.723351] [TS:51002888666] pcieport 0001:02:01.0: enabling device (0000 -> 0003)
[ 6.723531] [TS:51003068425] pcieport 0001:02:01.0: pciehp: Slot #0 AttnBtn+ PwrCtrl+ MRL+ AttnInd+ PwrInd+ HotPlug+ Surprise- Interlock- NoCompl- IbPresDis- LLActRep+
[ 6.724505] [TS:51004041786] pcieport 0001:02:02.0: Adding to iommu group 16
[ 6.724643] [TS:51004179980] pcieport 0001:02:02.0: enabling device (0000 -> 0003)
[ 6.724800] [TS:51004337397] pcieport 0001:02:02.0: pciehp: Slot #0 AttnBtn+ PwrCtrl+ MRL+ AttnInd+ PwrInd+ HotPlug+ Surprise- Interlock- NoCompl- IbPresDis- LLActRep+
[ 6.725610] [TS:51005146971] pcieport 0001:02:03.0: Adding to iommu group 17
[ 6.725745] [TS:51005282703] pcieport 0001:02:03.0: enabling device (0000 -> 0003)
[ 6.725960] [TS:51005497230] pcieport 0001:02:03.0: pciehp: Slot #0 AttnBtn+ PwrCtrl+ MRL+ AttnInd+ PwrInd+ HotPlug+ Surprise- Interlock- NoCompl- IbPresDis- LLActRep+
[ 6.726632] [TS:51006169249] pcieport 0001:02:04.0: Adding to iommu group 18
[ 6.726755] [TS:51006291841] pcieport 0001:02:04.0: enabling device (0000 -> 0003)
[ 6.726947] [TS:51006484564] pcieport 0001:02:04.0: pciehp: Slot #0 AttnBtn+ PwrCtrl+ MRL+ AttnInd+ PwrInd+ HotPlug+ Surprise- Interlock- NoCompl- IbPresDis- LLActRep+
[ 6.727599] [TS:51007135823] pcieport 0001:02:05.0: Adding to iommu group 19
[ 6.727696] [TS:51007233166] pcieport 0001:02:05.0: enabling device (0000 -> 0003)
[ 6.727844] [TS:51007381517] pcieport 0001:02:05.0: pciehp: Slot #0 AttnBtn+ PwrCtrl+ MRL+ AttnInd+ PwrInd+ HotPlug+ Surprise- Interlock- NoCompl- IbPresDis- LLActRep+
[ 6.768157] [TS:51047693971] pcieport 0001:99:00.0: Adding to iommu group 21
[ 6.800074] [TS:51079611434] tegra264-pcie a808420000.pcie: host bridge /bus@0/pcie@a808420000 ranges:
[ 6.800242] [TS:51079779138] tegra264-pcie a808420000.pcie: MEM 0x0030000000..0x0037ffffff -> 0x0030000000
[ 6.800254] [TS:51079791610] tegra264-pcie a808420000.pcie: MEM 0xb0c0000000..0xb87fffffff -> 0xb0c0000000
[ 6.800260] [TS:51079796906] tegra264-pcie a808420000.pcie: IO 0xb084000000..0xb0841fffff -> 0x0084000000
[ 6.800369] [TS:51079905804] tegra264-pcie a808420000.pcie: ECAM at [mem 0xb0b0000000-0xb0bfffffff] for [bus 00-ff]
[ 6.907110] [TS:51186647601] tegra264-pcie a808420000.pcie: PCIe Controller-2 Link is UP (Speed: 4)
[ 6.907250] [TS:51186787323] tegra264-pcie a808420000.pcie: PCI host bridge to bus 0002:00
[ 6.907302] [TS:51186839054] pci 0002:00:00.0: [10de:22d8] type 01 class 0x060400 PCIe Root Port
[ 6.910252] [TS:51189789017] pci 0002:01:00.0: [15b7:5036] type 00 class 0x010802 PCIe Endpoint
[ 6.910610] [TS:51190147499] pci 0002:01:00.0: 31.506 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x2 link at 0002:00:00.0 (capable of 63.012 Gb/s with 16.0 GT/s PCIe x4 link)
[ 6.921360] [TS:51200896897] pcieport 0002:00:00.0: Adding to iommu group 22
[ 6.922683] [TS:51202219925] pcieport 0002:00:00.0: PME: Signaling with IRQ 193
[ 6.924025] [TS:51203562175] pcieport 0002:00:00.0: AER: enabled with IRQ 180
[ 6.924544] [TS:51204081647] pcieport 0002:00:00.0: DPC: enabled with IRQ 179
[ 6.924547] [TS:51204084462] pcieport 0002:00:00.0: DPC: error containment capabilities: Int Msg #1, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 6.924854] [TS:51204390906] tegra264-pcie a808440000.pcie: host bridge /bus@0/pcie@a808440000 ranges:
[ 6.924881] [TS:51204418036] tegra264-pcie a808440000.pcie: MEM 0x0038000000..0x003fffffff -> 0x0038000000
[ 6.924902] [TS:51204438878] tegra264-pcie a808440000.pcie: MEM 0xb8c0000000..0xc07fffffff -> 0xb8c0000000
[ 6.924913] [TS:51204450564] tegra264-pcie a808440000.pcie: IO 0xb884000000..0xb8841fffff -> 0x0084000000
[ 6.925017] [TS:51204554314] tegra264-pcie a808440000.pcie: ECAM at [mem 0xb8b0000000-0xb8bfffffff] for [bus 00-ff]
[ 7.027259] [TS:51306796749] tegra264-pcie a808440000.pcie: PCIe Controller-3 Link is UP (Speed: 2)
[ 7.027415] [TS:51306952527] tegra264-pcie a808440000.pcie: PCI host bridge to bus 0003:00
[ 7.027473] [TS:51307010527] pci 0003:00:00.0: [10de:22da] type 01 class 0x060400 PCIe Root Port
[ 7.030230] [TS:51309766990] pci 0003:01:00.0: [1b4b:9235] type 00 class 0x010601 PCIe Legacy Endpoint
[ 7.041172] [TS:51320709017] pcieport 0003:00:00.0: Adding to iommu group 23
[ 7.042511] [TS:51322048184] pcieport 0003:00:00.0: PME: Signaling with IRQ 209
[ 7.043341] [TS:51322877980] pcieport 0003:00:00.0: AER: enabled with IRQ 196
[ 7.043803] [TS:51323340582] pcieport 0003:00:00.0: DPC: enabled with IRQ 195
[ 7.043806] [TS:51323343471] pcieport 0003:00:00.0: DPC: error containment capabilities: Int Msg #1, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 7.044115] [TS:51323652119] tegra264-pcie a808460000.pcie: host bridge /bus@0/pcie@a808460000 ranges:
[ 7.044127] [TS:51323664749] tegra264-pcie a808460000.pcie: MEM 0x0040000000..0x0047ffffff -> 0x0040000000
[ 7.044137] [TS:51323673851] tegra264-pcie a808460000.pcie: MEM 0xc0c0000000..0xc87fffffff -> 0xc0c0000000
[ 7.044142] [TS:51323678925] tegra264-pcie a808460000.pcie: IO 0xc084000000..0xc0841fffff -> 0x0084000000
[ 7.044257] [TS:51323794490] tegra264-pcie a808460000.pcie: ECAM at [mem 0xc0b0000000-0xc0bfffffff] for [bus 00-ff]
[ 7.147280] [TS:51426816767] tegra264-pcie a808460000.pcie: PCIe Controller-4 Link is UP (Speed: 5)
[ 7.147447] [TS:51426984202] tegra264-pcie a808460000.pcie: PCI host bridge to bus 0004:00
[ 7.147498] [TS:51427034906] pci 0004:00:00.0: [10de:22d6] type 01 class 0x060400 PCIe Root Port
[ 7.150239] [TS:51429775952] pci 0004:01:00.0: [15b3:1979] type 01 class 0x060400 PCIe Switch Upstream Port
[ 7.151770] [TS:51431307184] pci 0004:02:00.0: [15b3:1979] type 01 class 0x060400 PCIe Switch Downstream Port
[ 7.153303] [TS:51432839832] pci 0004:02:01.0: [15b3:1979] type 01 class 0x060400 PCIe Switch Downstream Port
[ 7.154792] [TS:51434329415] pci 0004:02:02.0: [15b3:1979] type 01 class 0x060400 PCIe Switch Downstream Port
[ 7.158244] [TS:51437781110] pci 0004:03:00.0: [15b3:1021] type 00 class 0x020000 PCIe Endpoint
[ 7.161171] [TS:51440708314] pci 0004:03:00.0: 252.056 Gb/s available PCIe bandwidth, limited by 32.0 GT/s PCIe x8 link at 0004:00:00.0 (capable of 504.112 Gb/s with 32.0 GT/s PCIe x16 link)
[ 7.162007] [TS:51441544286] pci 0004:03:00.1: [15b3:1021] type 00 class 0x020000 PCIe Endpoint
[ 7.165013] [TS:51444550082] pci 0004:04:00.0: [15b3:1979] type 01 class 0x060400 PCIe Switch Upstream Port
[ 7.166265] [TS:51445801832] pci 0004:04:00.0: 252.056 Gb/s available PCIe bandwidth, limited by 32.0 GT/s PCIe x8 link at 0004:00:00.0 (capable of 504.112 Gb/s with 32.0 GT/s PCIe x16 link)
[ 7.167454] [TS:51446990823] pci 0004:05:08.0: [15b3:1979] type 01 class 0x060400 PCIe Switch Downstream Port
[ 7.171398] [TS:51450935591] pci 0004:07:00.0: [15b3:1979] type 01 class 0x060400 PCIe Switch Upstream Port
[ 7.172661] [TS:51452198749] pci 0004:07:00.0: 252.056 Gb/s available PCIe bandwidth, limited by 32.0 GT/s PCIe x8 link at 0004:00:00.0 (capable of 504.112 Gb/s with 32.0 GT/s PCIe x16 link)
[ 7.173343] [TS:51452880638] pci 0004:08:00.0: [15b3:1979] type 01 class 0x060400 PCIe Switch Downstream Port
[ 7.177453] [TS:51456990758] pci 0004:09:00.0: [10de:2bb4] type 00 class 0x030000 PCIe Legacy Endpoint
[ 7.178053] [TS:51457590554] pci 0004:09:00.0: 252.056 Gb/s available PCIe bandwidth, limited by 32.0 GT/s PCIe x8 link at 0004:00:00.0 (capable of 504.112 Gb/s with 32.0 GT/s PCIe x16 link)
[ 7.178299] [TS:51457836749] pci 0004:09:00.1: [10de:22e8] type 00 class 0x040300 PCIe Endpoint
[ 7.193260] [TS:51472797277] pcieport 0004:00:00.0: Adding to iommu group 24
[ 7.193984] [TS:51473521545] pcieport 0004:00:00.0: PME: Signaling with IRQ 225
[ 7.194358] [TS:51473895017] pcieport 0004:00:00.0: AER: enabled with IRQ 212
[ 7.194884] [TS:51474421221] pcieport 0004:00:00.0: DPC: enabled with IRQ 211
[ 7.194887] [TS:51474423767] pcieport 0004:00:00.0: DPC: error containment capabilities: Int Msg #1, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 7.214165] [TS:51493702277] pcieport 0004:01:00.0: Adding to iommu group 25
[ 7.214289] [TS:51493826665] pcieport 0004:01:00.0: enabling device (0106 -> 0107)
[ 7.228154] [TS:51507691397] pcieport 0004:02:00.0: Adding to iommu group 26
[ 7.228725] [TS:51508262499] pcieport 0004:02:01.0: Adding to iommu group 27
[ 7.229261] [TS:51508798675] pcieport 0004:02:02.0: Adding to iommu group 28
[ 7.229362] [TS:51508899230] pcieport 0004:02:02.0: enabling device (0106 -> 0107)
[ 7.243116] [TS:51522652869] pcieport 0004:04:00.0: Adding to iommu group 27
[ 7.259123] [TS:51538659925] pcieport 0004:05:08.0: Adding to iommu group 27
[ 7.268115] [TS:51547652054] pcieport 0004:07:00.0: Adding to iommu group 28
[ 7.268252] [TS:51547789314] pcieport 0004:07:00.0: enabling device (0106 -> 0107)
[ 7.282117] [TS:51561654415] pcieport 0004:08:00.0: Adding to iommu group 28
[ 7.282240] [TS:51561777230] pcieport 0004:08:00.0: enabling device (0106 -> 0107)
[ 7.537665] [TS:51817201934] mlx5_core 0004:03:00.0: 252.056 Gb/s available PCIe bandwidth, limited by 32.0 GT/s PCIe x8 link at 0004:00:00.0 (capable of 504.112 Gb/s with 32.0 GT/s PCIe x16 link)
[ 7.908904] [TS:52188440897] mlx5_core 0004:03:00.0: mlx5_pcie_event:325:(pid 11): PCIe slot power capability was not advertised.
[ 8.012300] [TS:52291836943] mlx5_core 0004:03:00.1: 252.056 Gb/s available PCIe bandwidth, limited by 32.0 GT/s PCIe x8 link at 0004:00:00.0 (capable of 504.112 Gb/s with 32.0 GT/s PCIe x16 link)
[ 8.383300] [TS:52662836841] mlx5_core 0004:03:00.1: mlx5_pcie_event:325:(pid 117): PCIe slot power capability was not advertised.
[ 16.655263] [TS:60934799802] rtl8852ce 0001:cb:00.0: Adding to iommu group 58
[ 16.656129] [TS:60935666053] rtl8852ce 0001:cb:00.0: enabling device (0000 -> 0003)
[ 16.657250] [TS:60936786802] PHL: [BTC], hal_btc_init(): Init 8852C!!
[ 16.657283] [TS:60936820395] PHL: hal_init_int_default_value_8852ce : 0x21000000, 0x00180005, 0x00000000, 0x00600000, 0x00000004 (opt 0)
[ 16.695466] [TS:60975003062] input: HDA NVidia HDMI/DP,pcm=3 as /devices/platform/bus@0/a808460000.pcie/pci0004:00/0004:00:00.0/0004:01:00.0/0004:02:02.0/0004:07:00.0/0004:08:00.0/0004:09:00.1/sound/card1/input8
[ 16.695650] [TS:60975187043] input: HDA NVidia HDMI/DP,pcm=7 as /devices/platform/bus@0/a808460000.pcie/pci0004:00/0004:00:00.0/0004:01:00.0/0004:02:02.0/0004:07:00.0/0004:08:00.0/0004:09:00.1/sound/card1/input9
[ 16.695816] [TS:60975353182] input: HDA NVidia HDMI/DP,pcm=8 as /devices/platform/bus@0/a808460000.pcie/pci0004:00/0004:00:00.0/0004:01:00.0/0004:02:02.0/0004:07:00.0/0004:08:00.0/0004:09:00.1/sound/card1/input10
[ 16.695989] [TS:60975526506] input: HDA NVidia HDMI/DP,pcm=9 as /devices/platform/bus@0/a808460000.pcie/pci0004:00/0004:00:00.0/0004:01:00.0/0004:02:02.0/0004:07:00.0/0004:08:00.0/0004:09:00.1/sound/card1/input11
[ 17.479630] [TS:61759167071] rtk_btusb: read_ver_rsp->lmp_subver = 0x8852
[ 17.479637] [TS:61759174543] rtk_btusb: patch_entry->lmp_sub = 0x8852
[ 17.479640] [TS:61759177552] rtk_btusb: lmp_version = 0x8852
[ 17.479642] [TS:61759179441] rtk_btusb: config filename rtl8852cu_config
[ 17.484138] [TS:61763675043] rtk_btusb: fw name is rtl8852cu_fw
[ 17.487648] [TS:61767184839] rtk_btusb: lmp_version is 8852, project_id is 25, match!
[ 18.031636] [TS:62311172978] rtk_btusb: patch_entry->lmp_sub = 0x8852
[ 18.081528] [TS:62361064774] rtl8852ce 0001:cb:00.0 wlP1p203s0: renamed from wlan0
[ 35.819104] [TS:80098641678] VDD_3V3_WIFI: disabling
$ sudo nmcli device status
DEVICE TYPE STATE CONNECTION
enP1p53s0 ethernet connected Wired connection 2
enP1p3s0 ethernet connecting (getting IP configuration) Wired connection 1
enx4ecae275154e ethernet connecting (getting IP configuration) Wired connection 5
l4tbr0 bridge connected (externally) l4tbr0
lo loopback connected (externally) lo
docker0 bridge connected (externally) docker0
wlP1p203s0 wifi disconnected --
p2p-dev-wlP1p203s0 wifi-p2p disconnected --
enP4p3s0f0np0 ethernet unavailable --
enP4p3s0f1np1 ethernet unavailable --
usb0 ethernet unmanaged --
usb1 ethernet unmanaged --
$ rfkill list
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
Board kit:
$ sudo lspci
0002:01:00.0 Non-Volatile memory controller: Transcend Information, Inc. NVMe PCIe SSD 250H (rev 03)
[ 0.000000] [TS:59678206775] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.8.0-1019-nvidia-tegra-rt root=UUID=a4bd29bf-0698-4663-9d79-3766cb2d9f08 ro mminit_loglevel=4 preempt=full earlycon=tegra_utc,mmio32,0xc5a0000 video=efifb:off console=tty0 console=ttyUTC0,115200 clk_ignore_unused firmware_class.path=/etc/firmware fbcon=map:0 nospectre_bhb efi=runtime bl_prof_dataptr=6225920@0x2008010000 bl_prof_ro_ptr=65536@0x20 pci=pcie_bus_safe rd.driver.blacklist=nouveau nouveau.modeset=0 console=tty0 console=ttyUTC0,115200
[ 4.099671] [TS:64011188524] arm-smmu-v3 8806000000.iommu: option nvidia,tegra264-tlbi-race-fix
[ 4.900363] [TS:64811879941] pci-host-generic d0b0000000.pcie: host bridge /bus@0/pcie@d0b0000000 ranges:
[ 4.900380] [TS:64811897357] pci-host-generic d0b0000000.pcie: MEM 0x0020000000..0x0027ffffff -> 0x0020000000
[ 4.900390] [TS:64811906598] pci-host-generic d0b0000000.pcie: MEM 0xd0c0000000..0xd87fffffff -> 0xd0c0000000
[ 4.900395] [TS:64811912024] pci-host-generic d0b0000000.pcie: IO 0xd084000000..0xd0841fffff -> 0x0084000000
[ 4.900430] [TS:64811947107] pci-host-generic d0b0000000.pcie: ECAM at [mem 0xd0b0000000-0xd0bfffffff] for [bus 00-ff]
[ 5.002157] [TS:64913673885] pci-host-generic d0b0000000.pcie: PCI host bridge to bus 0000:00
[ 5.002215] [TS:64913731598] pci 0000:00:00.0: [10de:22e6] type 01 class 0x060400 PCIe Root Port
[ 5.004877] [TS:64916394117] pci 0000:01:00.0: [10de:2b00] type 00 class 0x030200 PCIe Endpoint
[ 5.005505] [TS:64917021941] pci 0000:01:00.0: 0.000 Gb/s available PCIe bandwidth, limited by Unknown x0 link at 0000:00:00.0 (capable of 32.000 Gb/s with 2.5 GT/s PCIe x16 link)
[ 5.012569] [TS:64924086468] pcieport 0000:00:00.0: Adding to iommu group 0
[ 5.013571] [TS:64925088450] pcieport 0000:00:00.0: PME: Signaling with IRQ 123
[ 5.014784] [TS:64926301320] pcieport 0000:00:00.0: AER: enabled with IRQ 125
[ 6.642537] [TS:66554054088] pcie_tegra264: loading out-of-tree module taints kernel.
[ 6.657975] [TS:66569492218] tegra264-pcie a808400000.pcie: host bridge /bus@0/pcie@a808400000 ranges:
[ 6.658000] [TS:66569516848] tegra264-pcie a808400000.pcie: MEM 0x0028000000..0x002bffffff -> 0x0028000000
[ 6.658010] [TS:66569526801] tegra264-pcie a808400000.pcie: MEM 0x002c000000..0x002fffffff -> 0x002c000000
[ 6.658017] [TS:66569534153] tegra264-pcie a808400000.pcie: MEM 0xa8c0000000..0xb07fffffff -> 0xa8c0000000
[ 6.658022] [TS:66569539274] tegra264-pcie a808400000.pcie: IO 0xa884000000..0xa8841fffff -> 0x0084000000
[ 6.658135] [TS:66569652366] tegra264-pcie a808400000.pcie: ECAM at [mem 0xa8b0000000-0xa8bfffffff] for [bus 00-ff]
[ 6.762739] [TS:66674256459] tegra264-pcie a808400000.pcie: PCIe Controller-1 Link is UP (Speed: 2)
[ 6.762880] [TS:66674397533] tegra264-pcie a808400000.pcie: PCI host bridge to bus 0001:00
[ 6.762941] [TS:66674457681] pci 0001:00:00.0: [10de:22d8] type 01 class 0x060400 PCIe Root Port
[ 6.765799] [TS:66677316181] pci 0001:01:00.0: [12d8:2608] type 01 class 0x060400 PCIe Switch Upstream Port
[ 6.766743] [TS:66678260394] pci 0001:02:01.0: [12d8:2608] type 01 class 0x060400 PCIe Switch Downstream Port
[ 6.767436] [TS:66678952922] pci 0001:02:02.0: [12d8:2608] type 01 class 0x060400 PCIe Switch Downstream Port
[ 6.768127] [TS:66679644459] pci 0001:02:03.0: [12d8:2608] type 01 class 0x060400 PCIe Switch Downstream Port
[ 6.768820] [TS:66680336894] pci 0001:02:04.0: [12d8:2608] type 01 class 0x060400 PCIe Switch Downstream Port
[ 6.769505] [TS:66681022551] pci 0001:02:05.0: [12d8:2608] type 01 class 0x060400 PCIe Switch Downstream Port
[ 6.771992] [TS:66683508848] pci 0001:03:00.0: [10ec:8168] type 00 class 0x020000 PCIe Endpoint
[ 6.772958] [TS:66684474764] pci 0001:35:00.0: [10ec:8168] type 00 class 0x020000 PCIe Endpoint
[ 6.773918] [TS:66685435283] pci 0001:67:00.0: [1c00:3450] type 00 class 0x070005 PCIe Legacy Endpoint
[ 6.774634] [TS:66686150922] pci 0001:99:00.0: [1a03:1150] type 01 class 0x060400 PCIe to PCI/PCI-X bridge
[ 6.778238] [TS:66689755357] pci 0001:cb:00.0: [10ec:c852] type 00 class 0x028000 PCIe Endpoint
[ 6.791010] [TS:66702526616] pcieport 0001:00:00.0: Adding to iommu group 13
[ 6.791928] [TS:66703444949] pcieport 0001:00:00.0: PME: Signaling with IRQ 168
[ 6.792509] [TS:66704026533] pcieport 0001:00:00.0: AER: enabled with IRQ 155
[ 6.792865] [TS:66704381811] pcieport 0001:00:00.0: DPC: enabled with IRQ 154
[ 6.792868] [TS:66704384672] pcieport 0001:00:00.0: DPC: error containment capabilities: Int Msg #1, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 6.809783] [TS:66721300487] pcieport 0001:01:00.0: Adding to iommu group 14
[ 6.809886] [TS:66721403412] pcieport 0001:01:00.0: enabling device (0000 -> 0003)
[ 6.821772] [TS:66733289450] pcieport 0001:02:01.0: Adding to iommu group 15
[ 6.821924] [TS:66733440607] pcieport 0001:02:01.0: enabling device (0000 -> 0003)
[ 6.822120] [TS:66733636598] pcieport 0001:02:01.0: pciehp: Slot #0 AttnBtn+ PwrCtrl+ MRL+ AttnInd+ PwrInd+ HotPlug+ Surprise- Interlock- NoCompl- IbPresDis- LLActRep+
[ 6.822690] [TS:66734206644] pcieport 0001:02:02.0: Adding to iommu group 16
[ 6.823027] [TS:66734543922] pcieport 0001:02:02.0: enabling device (0000 -> 0003)
[ 6.823181] [TS:66734698088] pcieport 0001:02:02.0: pciehp: Slot #0 AttnBtn+ PwrCtrl+ MRL+ AttnInd+ PwrInd+ HotPlug+ Surprise- Interlock- NoCompl- IbPresDis- LLActRep+
[ 6.823834] [TS:66735350764] pcieport 0001:02:03.0: Adding to iommu group 17
[ 6.823957] [TS:66735474487] pcieport 0001:02:03.0: enabling device (0000 -> 0003)
[ 6.824113] [TS:66735630431] pcieport 0001:02:03.0: pciehp: Slot #0 AttnBtn+ PwrCtrl+ MRL+ AttnInd+ PwrInd+ HotPlug+ Surprise- Interlock- NoCompl- IbPresDis- LLActRep+
[ 6.824674] [TS:66736190690] pcieport 0001:02:04.0: Adding to iommu group 18
[ 6.824809] [TS:66736325801] pcieport 0001:02:04.0: enabling device (0000 -> 0003)
[ 6.824956] [TS:66736473283] pcieport 0001:02:04.0: pciehp: Slot #0 AttnBtn+ PwrCtrl+ MRL+ AttnInd+ PwrInd+ HotPlug+ Surprise- Interlock- NoCompl- IbPresDis- LLActRep+
[ 6.825412] [TS:66736929311] pcieport 0001:02:05.0: Adding to iommu group 19
[ 6.825516] [TS:66737032838] pcieport 0001:02:05.0: enabling device (0000 -> 0003)
[ 6.825662] [TS:66737178672] pcieport 0001:02:05.0: pciehp: Slot #0 AttnBtn+ PwrCtrl+ MRL+ AttnInd+ PwrInd+ HotPlug+ Surprise- Interlock- NoCompl- IbPresDis- LLActRep+
[ 6.887780] [TS:66799296662] pcieport 0001:99:00.0: Adding to iommu group 21
[ 6.976620] [TS:66888137033] tegra264-pcie a808420000.pcie: host bridge /bus@0/pcie@a808420000 ranges:
[ 6.976627] [TS:66888144172] tegra264-pcie a808420000.pcie: MEM 0x0030000000..0x0037ffffff -> 0x0030000000
[ 6.976631] [TS:66888148514] tegra264-pcie a808420000.pcie: MEM 0xb0c0000000..0xb87fffffff -> 0xb0c0000000
[ 6.976634] [TS:66888151135] tegra264-pcie a808420000.pcie: IO 0xb084000000..0xb0841fffff -> 0x0084000000
[ 6.976707] [TS:66888223625] tegra264-pcie a808420000.pcie: ECAM at [mem 0xb0b0000000-0xb0bfffffff] for [bus 00-ff]
[ 7.081738] [TS:66993255385] tegra264-pcie a808420000.pcie: PCIe Controller-2 Link is UP (Speed: 4)
[ 7.081807] [TS:66993323811] tegra264-pcie a808420000.pcie: PCI host bridge to bus 0002:00
[ 7.081843] [TS:66993359811] pci 0002:00:00.0: [10de:22d8] type 01 class 0x060400 PCIe Root Port
[ 7.083405] [TS:66994921792] pci 0002:01:00.0: [1d79:2264] type 00 class 0x010802 PCIe Endpoint
[ 7.083751] [TS:66995268394] pci 0002:01:00.0: 31.506 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x2 link at 0002:00:00.0 (capable of 63.012 Gb/s with 16.0 GT/s PCIe x4 link)
[ 7.097780] [TS:67009297505] pcieport 0002:00:00.0: Adding to iommu group 22
[ 7.098682] [TS:67010198986] pcieport 0002:00:00.0: PME: Signaling with IRQ 193
[ 7.099482] [TS:67010998820] pcieport 0002:00:00.0: AER: enabled with IRQ 180
[ 7.100171] [TS:67011688227] pcieport 0002:00:00.0: DPC: enabled with IRQ 179
[ 7.100173] [TS:67011690135] pcieport 0002:00:00.0: DPC: error containment capabilities: Int Msg #1, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 7.100375] [TS:67011891690] tegra264-pcie a808440000.pcie: host bridge /bus@0/pcie@a808440000 ranges:
[ 7.100387] [TS:67011904098] tegra264-pcie a808440000.pcie: MEM 0x0038000000..0x003fffffff -> 0x0038000000
[ 7.100403] [TS:67011919672] tegra264-pcie a808440000.pcie: MEM 0xb8c0000000..0xc07fffffff -> 0xb8c0000000
[ 7.100411] [TS:67011928320] tegra264-pcie a808440000.pcie: IO 0xb884000000..0xb8841fffff -> 0x0084000000
[ 7.100484] [TS:67012000848] tegra264-pcie a808440000.pcie: ECAM at [mem 0xb8b0000000-0xb8bfffffff] for [bus 00-ff]
[ 7.201729] [TS:67113245653] tegra264-pcie a808440000.pcie: PCIe Controller-3 Link is UP (Speed: 2)
[ 7.201787] [TS:67113303912] tegra264-pcie a808440000.pcie: PCI host bridge to bus 0003:00
[ 7.201821] [TS:67113338477] pci 0003:00:00.0: [10de:22da] type 01 class 0x060400 PCIe Root Port
[ 7.203368] [TS:67114885236] pci 0003:01:00.0: [1b4b:9235] type 00 class 0x010601 PCIe Legacy Endpoint
[ 7.213771] [TS:67125288107] pcieport 0003:00:00.0: Adding to iommu group 23
[ 7.214643] [TS:67126160412] pcieport 0003:00:00.0: PME: Signaling with IRQ 209
[ 7.216069] [TS:67127585912] pcieport 0003:00:00.0: AER: enabled with IRQ 196
[ 7.217211] [TS:67128727570] pcieport 0003:00:00.0: DPC: enabled with IRQ 195
[ 7.217213] [TS:67128729561] pcieport 0003:00:00.0: DPC: error containment capabilities: Int Msg #1, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 7.217431] [TS:67128947875] tegra264-pcie a808460000.pcie: host bridge /bus@0/pcie@a808460000 ranges:
[ 7.217437] [TS:67128953533] tegra264-pcie a808460000.pcie: MEM 0x0040000000..0x0047ffffff -> 0x0040000000
[ 7.217440] [TS:67128957514] tegra264-pcie a808460000.pcie: MEM 0xc0c0000000..0xc87fffffff -> 0xc0c0000000
[ 7.217443] [TS:67128959848] tegra264-pcie a808460000.pcie: IO 0xc084000000..0xc0841fffff -> 0x0084000000
[ 7.217512] [TS:67129028959] tegra264-pcie a808460000.pcie: ECAM at [mem 0xc0b0000000-0xc0bfffffff] for [bus 00-ff]
[ 7.322726] [TS:67234243088] tegra264-pcie a808460000.pcie: PCIe Controller-4 Link is UP (Speed: 5)
[ 7.322798] [TS:67234314783] tegra264-pcie a808460000.pcie: PCI host bridge to bus 0004:00
[ 7.322832] [TS:67234348959] pci 0004:00:00.0: [10de:22d6] type 01 class 0x060400 PCIe Root Port
[ 7.324372] [TS:67235888875] pci 0004:01:00.0: [15b3:1979] type 01 class 0x060400 PCIe Switch Upstream Port
[ 7.325807] [TS:67237324264] pci 0004:02:00.0: [15b3:1979] type 01 class 0x060400 PCIe Switch Downstream Port
[ 7.327207] [TS:67238723996] pci 0004:02:01.0: [15b3:1979] type 01 class 0x060400 PCIe Switch Downstream Port
[ 7.327335] [TS:67238852033] pci 0004:02:01.0: PCI bridge to [bus 04-06]
[ 7.328618] [TS:67240135311] pci 0004:02:02.0: [15b3:1979] type 01 class 0x060400 PCIe Switch Downstream Port
[ 7.330975] [TS:67242492311] pci 0004:03:00.0: [15b3:1021] type 00 class 0x020000 PCIe Endpoint
[ 7.333847] [TS:67245364005] pci 0004:03:00.0: 252.056 Gb/s available PCIe bandwidth, limited by 32.0 GT/s PCIe x8 link at 0004:00:00.0 (capable of 504.112 Gb/s with 32.0 GT/s PCIe x16 link)
[ 7.334639] [TS:67246156162] pci 0004:03:00.1: [15b3:1021] type 00 class 0x020000 PCIe Endpoint
[ 7.337568] [TS:67249085079] pci 0004:04:00.0: [15b3:1979] type 01 class 0x060400 PCIe Switch Upstream Port
[ 7.338832] [TS:67250349255] pci 0004:04:00.0: 252.056 Gb/s available PCIe bandwidth, limited by 32.0 GT/s PCIe x8 link at 0004:00:00.0 (capable of 504.112 Gb/s with 32.0 GT/s PCIe x16 link)
[ 7.339671] [TS:67251188440] pci 0004:05:08.0: [15b3:1979] type 01 class 0x060400 PCIe Switch Downstream Port
[ 7.342755] [TS:67254272014] pci 0004:07:00.0: [15b3:1979] type 01 class 0x060400 PCIe Switch Upstream Port
[ 7.344011] [TS:67255528070] pci 0004:07:00.0: 252.056 Gb/s available PCIe bandwidth, limited by 32.0 GT/s PCIe x8 link at 0004:00:00.0 (capable of 504.112 Gb/s with 32.0 GT/s PCIe x16 link)
[ 7.344627] [TS:67256144005] pci 0004:08:00.0: [15b3:1979] type 01 class 0x060400 PCIe Switch Downstream Port
[ 7.347619] [TS:67259135588] pci 0004:09:00.0: [10de:2bb4] type 00 class 0x030000 PCIe Legacy Endpoint
[ 7.348201] [TS:67259718283] pci 0004:09:00.0: 252.056 Gb/s available PCIe bandwidth, limited by 32.0 GT/s PCIe x8 link at 0004:00:00.0 (capable of 504.112 Gb/s with 32.0 GT/s PCIe x16 link)
[ 7.348374] [TS:67259891320] pci 0004:09:00.1: [10de:22e8] type 00 class 0x040300 PCIe Endpoint
[ 7.382817] [TS:67294333986] pcieport 0004:00:00.0: Adding to iommu group 24
[ 7.383605] [TS:67295122449] pcieport 0004:00:00.0: PME: Signaling with IRQ 225
[ 7.384218] [TS:67295735412] pcieport 0004:00:00.0: AER: enabled with IRQ 212
[ 7.384510] [TS:67296026968] pcieport 0004:00:00.0: DPC: enabled with IRQ 211
[ 7.384512] [TS:67296028755] pcieport 0004:00:00.0: DPC: error containment capabilities: Int Msg #1, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 7.396791] [TS:67308308042] pcieport 0004:01:00.0: Adding to iommu group 25
[ 7.396903] [TS:67308419885] pcieport 0004:01:00.0: enabling device (0106 -> 0107)
[ 7.436772] [TS:67348289107] pcieport 0004:02:00.0: Adding to iommu group 26
[ 7.437233] [TS:67348750348] pcieport 0004:02:01.0: Adding to iommu group 27
[ 7.437657] [TS:67349173903] pcieport 0004:02:02.0: Adding to iommu group 28
[ 7.437735] [TS:67349251755] pcieport 0004:02:02.0: enabling device (0106 -> 0107)
[ 7.476745] [TS:67388262061] pcieport 0004:04:00.0: Adding to iommu group 27
[ 7.492839] [TS:67404356459] pcieport 0004:05:08.0: Adding to iommu group 27
[ 7.508760] [TS:67420276699] pcieport 0004:07:00.0: Adding to iommu group 28
[ 7.508839] [TS:67420356320] pcieport 0004:07:00.0: enabling device (0106 -> 0107)
[ 7.534754] [TS:67446270746] pcieport 0004:08:00.0: Adding to iommu group 28
[ 7.534837] [TS:67446354227] pcieport 0004:08:00.0: enabling device (0106 -> 0107)
[ 8.046640] [TS:67958157255] mlx5_core 0004:03:00.0: 252.056 Gb/s available PCIe bandwidth, limited by 32.0 GT/s PCIe x8 link at 0004:00:00.0 (capable of 504.112 Gb/s with 32.0 GT/s PCIe x16 link)
[ 8.413415] [TS:68324931903] mlx5_core 0004:03:00.0: mlx5_pcie_event:325:(pid 11): PCIe slot power capability was not advertised.
[ 8.520474] [TS:68431991338] mlx5_core 0004:03:00.1: 252.056 Gb/s available PCIe bandwidth, limited by 32.0 GT/s PCIe x8 link at 0004:00:00.0 (capable of 504.112 Gb/s with 32.0 GT/s PCIe x16 link)
[ 8.891265] [TS:68802781755] mlx5_core 0004:03:00.1: mlx5_pcie_event:325:(pid 101): PCIe slot power capability was not advertised.
[ 15.858920] [TS:75770437244] systemd[1]: /etc/systemd/system/wifi-pcie-fix.service:11: Missing '=', ignoring line.
[ 18.591683] [TS:78503200355] input: HDA NVidia HDMI/DP,pcm=3 as /devices/platform/bus@0/a808460000.pcie/pci0004:00/0004:00:00.0/0004:01:00.0/0004:02:02.0/0004:07:00.0/0004:08:00.0/0004:09:00.1/sound/card1/input15
[ 18.597446] [TS:78508963206] input: HDA NVidia HDMI/DP,pcm=7 as /devices/platform/bus@0/a808460000.pcie/pci0004:00/0004:00:00.0/0004:01:00.0/0004:02:02.0/0004:07:00.0/0004:08:00.0/0004:09:00.1/sound/card1/input16
[ 18.602616] [TS:78514132966] input: HDA NVidia HDMI/DP,pcm=8 as /devices/platform/bus@0/a808460000.pcie/pci0004:00/0004:00:00.0/0004:01:00.0/0004:02:02.0/0004:07:00.0/0004:08:00.0/0004:09:00.1/sound/card1/input17
[ 18.606433] [TS:78517949827] input: HDA NVidia HDMI/DP,pcm=9 as /devices/platform/bus@0/a808460000.pcie/pci0004:00/0004:00:00.0/0004:01:00.0/0004:02:02.0/0004:07:00.0/0004:08:00.0/0004:09:00.1/sound/card1/input18
[ 19.030089] [TS:78941606280] rtl8852ce 0001:cb:00.0: Adding to iommu group 58
[ 19.030363] [TS:78941879808] rtl8852ce 0001:cb:00.0: enabling device (0000 -> 0003)
[ 19.032052] [TS:78943568845] PHL: [BTC], hal_btc_init(): Init 8852C!!
[ 19.032101] [TS:78943618392] PHL: hal_init_int_default_value_8852ce : 0x21000000, 0x00180005, 0x00000000, 0x00600000, 0x00000004 (opt 0)
[ 20.004178] [TS:79915695104] rtl8852ce 0001:cb:00.0 wlP1p203s0: renamed from wlan0
[ 20.035661] [TS:79947177873] Bluetooth: hci0: RTL: examining hci_ver=0c hci_rev=000c lmp_ver=0c lmp_subver=8852
[ 20.037660] [TS:79949176947] Bluetooth: hci0: RTL: rom_version status=0 version=1
[ 20.037664] [TS:79949180697] Bluetooth: hci0: RTL: loading rtl_bt/rtl8852cu_fw_v2.bin
[ 20.124188] [TS:80035705382] Bluetooth: hci0: RTL: loading rtl_bt/rtl8852cu_config.bin
[ 20.145885] [TS:80057402410] Bluetooth: hci0: RTL: cfg_sz 6, total sz 71983
[ 20.809671] [TS:80721188030] Bluetooth: hci0: RTL: fw version 0x040d7225
[ 26.637336] [TS:86548852686] nvidia 0004:09:00.0: enabling device (0100 -> 0103)
[ 28.610054] [TS:88521571473] IPMI message handler: version 39.2
[ 34.938859] [TS:94850376379] [BB]halbb_wifi_event_notify: connect start: rssi=0xFF, set to RSSI_MAX
[ 34.938863] [TS:94850380139] [BB]halbb_wifi_event_notify: connect start: PDth=110
[ 35.394855] [TS:95306372120] [BB]halbb_wifi_event_notify: connect start: rssi=0xFF, set to RSSI_MAX
[ 35.394863] [TS:95306380194] [BB]halbb_wifi_event_notify: connect start: PDth=110
[ 35.508852] [TS:95420369055] 1A24=0x00e52fee, 1A34=0x02802f76, 1A64=0x005f04e5, 1A08=0x28cf0008
[ 35.817791] [TS:95729308277] VDD_3V3_WIFI: disabling
wlP1p203s0 wifi connected DS-Team
enx86359b9ce967 ethernet connecting (getting IP configuration) Wired connection 5
$ rfkill list
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
Bad boot:
Devkit:
$ sudo lspci
[ 0.000000] [TS:45613940546] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.8.0-1019-nvidia-tegra-rt root=UUID=695df0ed-0ea3-49d6-9fde-386c7985ed34 ro mminit_loglevel=4 preempt=full earlycon=tegra_utc,mmio32,0xc5a0000 video=efifb:off console=tty0 console=ttyUTC0,115200 clk_ignore_unused firmware_class.path=/etc/firmware fbcon=map:0 nospectre_bhb efi=runtime bl_prof_dataptr=6225920@0x2008010000 bl_prof_ro_ptr=65536@0x20 pci=pcie_bus_safe rd.driver.blacklist=nouveau nouveau.modeset=0 console=tty0 console=ttyUTC0,115200
[ 1.244856] [TS:47088524731] GICv3: CPU11: using allocated LPI pending table @0x00000001003d0000
[ 4.877005] [TS:50720673925] pci-host-generic d0b0000000.pcie: host bridge /bus@0/pcie@d0b0000000 ranges:
[ 4.877034] [TS:50720703156] pci-host-generic d0b0000000.pcie: MEM 0x0020000000..0x0027ffffff -> 0x0020000000
[ 4.877044] [TS:50720713110] pci-host-generic d0b0000000.pcie: MEM 0xd0c0000000..0xd87fffffff -> 0xd0c0000000
[ 4.877050] [TS:50720718943] pci-host-generic d0b0000000.pcie: IO 0xd084000000..0xd0841fffff -> 0x0084000000
[ 4.877097] [TS:50720765851] pci-host-generic d0b0000000.pcie: ECAM at [mem 0xd0b0000000-0xd0bfffffff] for [bus 00-ff]
[ 4.986352] [TS:50830020758] pci-host-generic d0b0000000.pcie: PCI host bridge to bus 0000:00
[ 4.986405] [TS:50830074193] pci 0000:00:00.0: [10de:22e6] type 01 class 0x060400 PCIe Root Port
[ 4.989084] [TS:50832753008] pci 0000:01:00.0: [10de:2b00] type 00 class 0x030200 PCIe Endpoint
[ 4.989714] [TS:50833382416] pci 0000:01:00.0: 0.000 Gb/s available PCIe bandwidth, limited by Unknown x0 link at 0000:00:00.0 (capable of 32.000 Gb/s with 2.5 GT/s PCIe x16 link)
[ 4.997721] [TS:50841390212] pcieport 0000:00:00.0: Adding to iommu group 0
[ 4.998696] [TS:50842365258] pcieport 0000:00:00.0: PME: Signaling with IRQ 123
[ 4.999745] [TS:50843414008] pcieport 0000:00:00.0: AER: enabled with IRQ 125
[ 6.690894] [TS:52534562924] pcie_tegra264: loading out-of-tree module taints kernel.
[ 6.699706] [TS:52543374860] tegra264-pcie a808400000.pcie: host bridge /bus@0/pcie@a808400000 ranges:
[ 6.699728] [TS:52543397073] tegra264-pcie a808400000.pcie: MEM 0x0028000000..0x002bffffff -> 0x0028000000
[ 6.699738] [TS:52543406823] tegra264-pcie a808400000.pcie: MEM 0x002c000000..0x002fffffff -> 0x002c000000
[ 6.699745] [TS:52543413610] tegra264-pcie a808400000.pcie: MEM 0xa8c0000000..0xb07fffffff -> 0xa8c0000000
[ 6.699750] [TS:52543418360] tegra264-pcie a808400000.pcie: IO 0xa884000000..0xa8841fffff -> 0x0084000000
[ 6.699856] [TS:52543525249] tegra264-pcie a808400000.pcie: ECAM at [mem 0xa8b0000000-0xa8bfffffff] for [bus 00-ff]
[ 6.801922] [TS:52645590489] tegra264-pcie a808400000.pcie: PCIe Controller-1 Link is UP (Speed: 2)
[ 6.802124] [TS:52645792508] tegra264-pcie a808400000.pcie: PCI host bridge to bus 0001:00
[ 6.802186] [TS:52645854573] pci 0001:00:00.0: [10de:22d8] type 01 class 0x060400 PCIe Root Port
[ 6.805408] [TS:52649076573] pci 0001:01:00.0: [12d8:2608] type 01 class 0x060400 PCIe Switch Upstream Port
[ 6.806368] [TS:52650037017] pci 0001:02:01.0: [12d8:2608] type 01 class 0x060400 PCIe Switch Downstream Port
[ 6.807082] [TS:52650750656] pci 0001:02:02.0: [12d8:2608] type 01 class 0x060400 PCIe Switch Downstream Port
[ 6.807765] [TS:52651433499] pci 0001:02:03.0: [12d8:2608] type 01 class 0x060400 PCIe Switch Downstream Port
[ 6.808458] [TS:52652126962] pci 0001:02:04.0: [12d8:2608] type 01 class 0x060400 PCIe Switch Downstream Port
[ 6.809157] [TS:52652825480] pci 0001:02:05.0: [12d8:2608] type 01 class 0x060400 PCIe Switch Downstream Port
[ 6.811664] [TS:52655333137] pci 0001:03:00.0: [10ec:8168] type 00 class 0x020000 PCIe Endpoint
[ 6.812652] [TS:52656320350] pci 0001:35:00.0: [10ec:8168] type 00 class 0x020000 PCIe Endpoint
[ 6.813626] [TS:52657294304] pci 0001:67:00.0: [1c00:3450] type 00 class 0x070005 PCIe Legacy Endpoint
[ 6.814356] [TS:52658024758] pci 0001:99:00.0: [1a03:1150] type 01 class 0x060400 PCIe to PCI/PCI-X bridge
[ 6.851186] [TS:52694854610] pcieport 0001:00:00.0: Adding to iommu group 13
[ 6.851938] [TS:52695606887] pcieport 0001:00:00.0: PME: Signaling with IRQ 168
[ 6.853047] [TS:52696715748] pcieport 0001:00:00.0: AER: enabled with IRQ 155
[ 6.853423] [TS:52697091276] pcieport 0001:00:00.0: DPC: enabled with IRQ 154
[ 6.853425] [TS:52697093971] pcieport 0001:00:00.0: DPC: error containment capabilities: Int Msg #1, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 6.889958] [TS:52733626424] pcieport 0001:01:00.0: Adding to iommu group 14
[ 6.890061] [TS:52733729489] pcieport 0001:01:00.0: enabling device (0000 -> 0003)
[ 6.916953] [TS:52760622036] pcieport 0001:02:01.0: Adding to iommu group 15
[ 6.917088] [TS:52760756887] pcieport 0001:02:01.0: enabling device (0000 -> 0003)
[ 6.917248] [TS:52760917221] pcieport 0001:02:01.0: pciehp: Slot #0 AttnBtn+ PwrCtrl+ MRL+ AttnInd+ PwrInd+ HotPlug+ Surprise- Interlock- NoCompl- IbPresDis- LLActRep+
[ 6.918779] [TS:52762447961] pcieport 0001:02:02.0: Adding to iommu group 16
[ 6.918919] [TS:52762588202] pcieport 0001:02:02.0: enabling device (0000 -> 0003)
[ 6.919069] [TS:52762738063] pcieport 0001:02:02.0: pciehp: Slot #0 AttnBtn+ PwrCtrl+ MRL+ AttnInd+ PwrInd+ HotPlug+ Surprise- Interlock- NoCompl- IbPresDis- LLActRep+
[ 6.919727] [TS:52763395332] pcieport 0001:02:03.0: Adding to iommu group 17
[ 6.919844] [TS:52763512730] pcieport 0001:02:03.0: enabling device (0000 -> 0003)
[ 6.920068] [TS:52763736776] pcieport 0001:02:03.0: pciehp: Slot #0 AttnBtn+ PwrCtrl+ MRL+ AttnInd+ PwrInd+ HotPlug+ Surprise- Interlock- NoCompl- IbPresDis- LLActRep+
[ 6.920508] [TS:52764176360] pcieport 0001:02:04.0: Adding to iommu group 18
[ 6.920616] [TS:52764284600] pcieport 0001:02:04.0: enabling device (0000 -> 0003)
[ 6.920759] [TS:52764427406] pcieport 0001:02:04.0: pciehp: Slot #0 AttnBtn+ PwrCtrl+ MRL+ AttnInd+ PwrInd+ HotPlug+ Surprise- Interlock- NoCompl- IbPresDis- LLActRep+
[ 6.922029] [TS:52765697276] pcieport 0001:02:05.0: Adding to iommu group 19
[ 6.922128] [TS:52765796739] pcieport 0001:02:05.0: enabling device (0000 -> 0003)
[ 6.922281] [TS:52765950128] pcieport 0001:02:05.0: pciehp: Slot #0 AttnBtn+ PwrCtrl+ MRL+ AttnInd+ PwrInd+ HotPlug+ Surprise- Interlock- NoCompl- IbPresDis- LLActRep+
[ 6.983961] [TS:52827629378] pcieport 0001:99:00.0: Adding to iommu group 21
[ 7.017744] [TS:52861412350] tegra264-pcie a808420000.pcie: host bridge /bus@0/pcie@a808420000 ranges:
[ 7.017756] [TS:52861424526] tegra264-pcie a808420000.pcie: MEM 0x0030000000..0x0037ffffff -> 0x0030000000
[ 7.017764] [TS:52861432952] tegra264-pcie a808420000.pcie: MEM 0xb0c0000000..0xb87fffffff -> 0xb0c0000000
[ 7.017769] [TS:52861438258] tegra264-pcie a808420000.pcie: IO 0xb084000000..0xb0841fffff -> 0x0084000000
[ 7.017859] [TS:52861528184] tegra264-pcie a808420000.pcie: ECAM at [mem 0xb0b0000000-0xb0bfffffff] for [bus 00-ff]
[ 7.122104] [TS:52965773156] tegra264-pcie a808420000.pcie: PCIe Controller-2 Link is UP (Speed: 4)
[ 7.122235] [TS:52965903647] tegra264-pcie a808420000.pcie: PCI host bridge to bus 0002:00
[ 7.122282] [TS:52965950563] pci 0002:00:00.0: [10de:22d8] type 01 class 0x060400 PCIe Root Port
[ 7.124947] [TS:52968616165] pci 0002:01:00.0: [15b7:5036] type 00 class 0x010802 PCIe Endpoint
[ 7.125299] [TS:52968968091] pci 0002:01:00.0: 31.506 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x2 link at 0002:00:00.0 (capable of 63.012 Gb/s with 16.0 GT/s PCIe x4 link)
[ 7.141011] [TS:52984679415] pcieport 0002:00:00.0: Adding to iommu group 22
[ 7.142095] [TS:52985763897] pcieport 0002:00:00.0: PME: Signaling with IRQ 193
[ 7.143187] [TS:52986856193] pcieport 0002:00:00.0: AER: enabled with IRQ 180
[ 7.144113] [TS:52987782267] pcieport 0002:00:00.0: DPC: enabled with IRQ 179
[ 7.144117] [TS:52987785285] pcieport 0002:00:00.0: DPC: error containment capabilities: Int Msg #1, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 7.144358] [TS:52988027193] tegra264-pcie a808440000.pcie: host bridge /bus@0/pcie@a808440000 ranges:
[ 7.144369] [TS:52988038202] tegra264-pcie a808440000.pcie: MEM 0x0038000000..0x003fffffff -> 0x0038000000
[ 7.144377] [TS:52988045989] tegra264-pcie a808440000.pcie: MEM 0xb8c0000000..0xc07fffffff -> 0xb8c0000000
[ 7.144383] [TS:52988051406] tegra264-pcie a808440000.pcie: IO 0xb884000000..0xb8841fffff -> 0x0084000000
[ 7.144451] [TS:52988120156] tegra264-pcie a808440000.pcie: ECAM at [mem 0xb8b0000000-0xb8bfffffff] for [bus 00-ff]
[ 7.250096] [TS:53093764878] tegra264-pcie a808440000.pcie: PCIe Controller-3 Link is UP (Speed: 2)
[ 7.250224] [TS:53093892684] tegra264-pcie a808440000.pcie: PCI host bridge to bus 0003:00
[ 7.250273] [TS:53093941461] pci 0003:00:00.0: [10de:22da] type 01 class 0x060400 PCIe Root Port
[ 7.253009] [TS:53096677369] pci 0003:01:00.0: [1b4b:9235] type 00 class 0x010601 PCIe Legacy Endpoint
[ 7.263963] [TS:53107631406] pcieport 0003:00:00.0: Adding to iommu group 23
[ 7.265087] [TS:53108756008] pcieport 0003:00:00.0: PME: Signaling with IRQ 209
[ 7.266165] [TS:53109834008] pcieport 0003:00:00.0: AER: enabled with IRQ 196
[ 7.266675] [TS:53110343378] pcieport 0003:00:00.0: DPC: enabled with IRQ 195
[ 7.266677] [TS:53110346258] pcieport 0003:00:00.0: DPC: error containment capabilities: Int Msg #1, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 7.266960] [TS:53110629147] tegra264-pcie a808460000.pcie: host bridge /bus@0/pcie@a808460000 ranges:
[ 7.266972] [TS:53110640554] tegra264-pcie a808460000.pcie: MEM 0x0040000000..0x0047ffffff -> 0x0040000000
[ 7.266980] [TS:53110648906] tegra264-pcie a808460000.pcie: MEM 0xc0c0000000..0xc87fffffff -> 0xc0c0000000
[ 7.267006] [TS:53110674591] tegra264-pcie a808460000.pcie: IO 0xc084000000..0xc0841fffff -> 0x0084000000
[ 7.267931] [TS:53111600017] tegra264-pcie a808460000.pcie: ECAM at [mem 0xc0b0000000-0xc0bfffffff] for [bus 00-ff]
[ 7.370087] [TS:53213755535] tegra264-pcie a808460000.pcie: PCIe Controller-4 Link is UP (Speed: 5)
[ 7.370217] [TS:53213885489] tegra264-pcie a808460000.pcie: PCI host bridge to bus 0004:00
[ 7.370262] [TS:53213930869] pci 0004:00:00.0: [10de:22d6] type 01 class 0x060400 PCIe Root Port
[ 7.372945] [TS:53216613758] pci 0004:01:00.0: [15b3:1979] type 01 class 0x060400 PCIe Switch Upstream Port
[ 7.374462] [TS:53218130813] pci 0004:02:00.0: [15b3:1979] type 01 class 0x060400 PCIe Switch Downstream Port
[ 7.375983] [TS:53219651721] pci 0004:02:01.0: [15b3:1979] type 01 class 0x060400 PCIe Switch Downstream Port
[ 7.377469] [TS:53221137545] pci 0004:02:02.0: [15b3:1979] type 01 class 0x060400 PCIe Switch Downstream Port
[ 7.380916] [TS:53224585211] pci 0004:03:00.0: [15b3:1021] type 00 class 0x020000 PCIe Endpoint
[ 7.383804] [TS:53227472443] pci 0004:03:00.0: 252.056 Gb/s available PCIe bandwidth, limited by 32.0 GT/s PCIe x8 link at 0004:00:00.0 (capable of 504.112 Gb/s with 32.0 GT/s PCIe x16 link)
[ 7.384643] [TS:53228311535] pci 0004:03:00.1: [15b3:1021] type 00 class 0x020000 PCIe Endpoint
[ 7.387667] [TS:53231335730] pci 0004:04:00.0: [15b3:1979] type 01 class 0x060400 PCIe Switch Upstream Port
[ 7.388899] [TS:53232568258] pci 0004:04:00.0: 252.056 Gb/s available PCIe bandwidth, limited by 32.0 GT/s PCIe x8 link at 0004:00:00.0 (capable of 504.112 Gb/s with 32.0 GT/s PCIe x16 link)
[ 7.390090] [TS:53233758461] pci 0004:05:08.0: [15b3:1979] type 01 class 0x060400 PCIe Switch Downstream Port
[ 7.394045] [TS:53237713906] pci 0004:07:00.0: [15b3:1979] type 01 class 0x060400 PCIe Switch Upstream Port
[ 7.395310] [TS:53238978850] pci 0004:07:00.0: 252.056 Gb/s available PCIe bandwidth, limited by 32.0 GT/s PCIe x8 link at 0004:00:00.0 (capable of 504.112 Gb/s with 32.0 GT/s PCIe x16 link)
[ 7.395998] [TS:53239666934] pci 0004:08:00.0: [15b3:1979] type 01 class 0x060400 PCIe Switch Downstream Port
[ 7.400850] [TS:53244519091] pci 0004:09:00.0: [10de:2bb4] type 00 class 0x030000 PCIe Legacy Endpoint
[ 7.401468] [TS:53245136739] pci 0004:09:00.0: 252.056 Gb/s available PCIe bandwidth, limited by 32.0 GT/s PCIe x8 link at 0004:00:00.0 (capable of 504.112 Gb/s with 32.0 GT/s PCIe x16 link)
[ 7.401720] [TS:53245388721] pci 0004:09:00.1: [10de:22e8] type 00 class 0x040300 PCIe Endpoint
[ 7.444989] [TS:53288658258] pcieport 0004:00:00.0: Adding to iommu group 24
[ 7.445951] [TS:53289619656] pcieport 0004:00:00.0: PME: Signaling with IRQ 225
[ 7.446745] [TS:53290413841] pcieport 0004:00:00.0: AER: enabled with IRQ 212
[ 7.447143] [TS:53290811610] pcieport 0004:00:00.0: DPC: enabled with IRQ 211
[ 7.447146] [TS:53290814610] pcieport 0004:00:00.0: DPC: error containment capabilities: Int Msg #1, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 7.473970] [TS:53317638776] pcieport 0004:01:00.0: Adding to iommu group 25
[ 7.474123] [TS:53317791424] pcieport 0004:01:00.0: enabling device (0106 -> 0107)
[ 7.487966] [TS:53331634878] pcieport 0004:02:00.0: Adding to iommu group 26
[ 7.488549] [TS:53332217674] pcieport 0004:02:01.0: Adding to iommu group 27
[ 7.489126] [TS:53332794730] pcieport 0004:02:02.0: Adding to iommu group 28
[ 7.490043] [TS:53333712258] pcieport 0004:02:02.0: enabling device (0106 -> 0107)
[ 7.510930] [TS:53354599082] pcieport 0004:04:00.0: Adding to iommu group 27
[ 7.527936] [TS:53371604359] pcieport 0004:05:08.0: Adding to iommu group 27
[ 7.542978] [TS:53386646971] pcieport 0004:07:00.0: Adding to iommu group 28
[ 7.543047] [TS:53386715869] pcieport 0004:07:00.0: enabling device (0106 -> 0107)
[ 7.550935] [TS:53394603406] pcieport 0004:08:00.0: Adding to iommu group 28
[ 7.551052] [TS:53394720535] pcieport 0004:08:00.0: enabling device (0106 -> 0107)
[ 7.815714] [TS:53659382619] mlx5_core 0004:03:00.0: 252.056 Gb/s available PCIe bandwidth, limited by 32.0 GT/s PCIe x8 link at 0004:00:00.0 (capable of 504.112 Gb/s with 32.0 GT/s PCIe x16 link)
[ 8.177637] [TS:54021305471] mlx5_core 0004:03:00.0: mlx5_pcie_event:325:(pid 11): PCIe slot power capability was not advertised.
[ 8.266582] [TS:54110250980] mlx5_core 0004:03:00.1: 252.056 Gb/s available PCIe bandwidth, limited by 32.0 GT/s PCIe x8 link at 0004:00:00.0 (capable of 504.112 Gb/s with 32.0 GT/s PCIe x16 link)
[ 8.633760] [TS:54477428757] mlx5_core 0004:03:00.1: mlx5_pcie_event:325:(pid 109): PCIe slot power capability was not advertised.
[ 16.885600] [TS:62729269052] input: HDA NVidia HDMI/DP,pcm=3 as /devices/platform/bus@0/a808460000.pcie/pci0004:00/0004:00:00.0/0004:01:00.0/0004:02:02.0/0004:07:00.0/0004:08:00.0/0004:09:00.1/sound/card1/input5
[ 16.885755] [TS:62729423311] input: HDA NVidia HDMI/DP,pcm=7 as /devices/platform/bus@0/a808460000.pcie/pci0004:00/0004:00:00.0/0004:01:00.0/0004:02:02.0/0004:07:00.0/0004:08:00.0/0004:09:00.1/sound/card1/input6
[ 16.885899] [TS:62729567311] input: HDA NVidia HDMI/DP,pcm=8 as /devices/platform/bus@0/a808460000.pcie/pci0004:00/0004:00:00.0/0004:01:00.0/0004:02:02.0/0004:07:00.0/0004:08:00.0/0004:09:00.1/sound/card1/input7
[ 16.886115] [TS:62729784228] input: HDA NVidia HDMI/DP,pcm=9 as /devices/platform/bus@0/a808460000.pcie/pci0004:00/0004:00:00.0/0004:01:00.0/0004:02:02.0/0004:07:00.0/0004:08:00.0/0004:09:00.1/sound/card1/input8
[ 18.311253] [TS:64154921876] rtk_btusb: read_ver_rsp->lmp_subver = 0x8852
[ 18.311257] [TS:64154926117] rtk_btusb: patch_entry->lmp_sub = 0x8852
[ 18.311259] [TS:64154928080] rtk_btusb: lmp_version = 0x8852
[ 18.311260] [TS:64154929135] rtk_btusb: config filename rtl8852cu_config
[ 18.311503] [TS:64155171691] rtk_btusb: fw name is rtl8852cu_fw
[ 18.314255] [TS:64157924228] rtk_btusb: lmp_version is 8852, project_id is 25, match!
[ 18.874355] [TS:64718023413] rtk_btusb: patch_entry->lmp_sub = 0x8852
[ 35.306121] [TS:81149790002] VDD_3V3_WIFI: disabling
enP1p3s0 ethernet disconnected --
enx9eadc0adcd8d ethernet disconnected --
rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
Board kit:
$ sudo lspci
[ 0.000000] [TS:53706926230] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.8.0-1019-nvidia-tegra-rt root=UUID=a4bd29bf-0698-4663-9d79-3766cb2d9f08 ro mminit_loglevel=4 preempt=full earlycon=tegra_utc,mmio32,0xc5a0000 video=efifb:off console=tty0 console=ttyUTC0,115200 clk_ignore_unused firmware_class.path=/etc/firmware fbcon=map:0 nospectre_bhb efi=runtime bl_prof_dataptr=6225920@0x2008010000 bl_prof_ro_ptr=65536@0x20 pci=pcie_bus_safe rd.driver.blacklist=nouveau nouveau.modeset=0 console=tty0 console=ttyUTC0,115200
[ 1.253415] [TS:55189788526] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9540000
[ 4.866393] [TS:58802766636] pci-host-generic d0b0000000.pcie: host bridge /bus@0/pcie@d0b0000000 ranges:
[ 4.866403] [TS:58802776479] pci-host-generic d0b0000000.pcie: MEM 0x0020000000..0x0027ffffff -> 0x0020000000
[ 4.866407] [TS:58802780914] pci-host-generic d0b0000000.pcie: MEM 0xd0c0000000..0xd87fffffff -> 0xd0c0000000
[ 4.866410] [TS:58802783423] pci-host-generic d0b0000000.pcie: IO 0xd084000000..0xd0841fffff -> 0x0084000000
[ 4.866430] [TS:58802803210] pci-host-generic d0b0000000.pcie: ECAM at [mem 0xd0b0000000-0xd0bfffffff] for [bus 00-ff]
[ 4.969183] [TS:58905556673] pci-host-generic d0b0000000.pcie: PCI host bridge to bus 0000:00
[ 4.969220] [TS:58905593118] pci 0000:00:00.0: [10de:22e6] type 01 class 0x060400 PCIe Root Port
[ 4.970616] [TS:58906989757] pci 0000:01:00.0: [10de:2b00] type 00 class 0x030200 PCIe Endpoint
[ 4.971221] [TS:58907594007] pci 0000:01:00.0: 0.000 Gb/s available PCIe bandwidth, limited by Unknown x0 link at 0000:00:00.0 (capable of 32.000 Gb/s with 2.5 GT/s PCIe x16 link)
[ 4.982691] [TS:58919064627] pcieport 0000:00:00.0: Adding to iommu group 0
[ 4.983432] [TS:58919804988] pcieport 0000:00:00.0: PME: Signaling with IRQ 123
[ 4.984067] [TS:58920440571] pcieport 0000:00:00.0: AER: enabled with IRQ 125
[ 6.431253] [TS:60367626080] pcie_tegra264: loading out-of-tree module taints kernel.
[ 6.431836] [TS:60368209090] tegra264-pcie a808400000.pcie: host bridge /bus@0/pcie@a808400000 ranges:
[ 6.431851] [TS:60368224691] tegra264-pcie a808400000.pcie: MEM 0x0028000000..0x002bffffff -> 0x0028000000
[ 6.431863] [TS:60368236664] tegra264-pcie a808400000.pcie: MEM 0x002c000000..0x002fffffff -> 0x002c000000
[ 6.431870] [TS:60368243479] tegra264-pcie a808400000.pcie: MEM 0xa8c0000000..0xb07fffffff -> 0xa8c0000000
[ 6.431875] [TS:60368248432] tegra264-pcie a808400000.pcie: IO 0xa884000000..0xa8841fffff -> 0x0084000000
[ 6.431975] [TS:60368347988] tegra264-pcie a808400000.pcie: ECAM at [mem 0xa8b0000000-0xa8bfffffff] for [bus 00-ff]
[ 6.537011] [TS:60473384256] tegra264-pcie a808400000.pcie: PCIe Controller-1 Link is UP (Speed: 2)
[ 6.537138] [TS:60473511460] tegra264-pcie a808400000.pcie: PCI host bridge to bus 0001:00
[ 6.537193] [TS:60473566932] pci 0001:00:00.0: [10de:22d8] type 01 class 0x060400 PCIe Root Port
[ 6.540011] [TS:60476384266] pci 0001:01:00.0: [12d8:2608] type 01 class 0x060400 PCIe Switch Upstream Port
[ 6.540981] [TS:60477354830] pci 0001:02:01.0: [12d8:2608] type 01 class 0x060400 PCIe Switch Downstream Port
[ 6.541796] [TS:60478169664] pci 0001:02:02.0: [12d8:2608] type 01 class 0x060400 PCIe Switch Downstream Port
[ 6.542503] [TS:60478876941] pci 0001:02:03.0: [12d8:2608] type 01 class 0x060400 PCIe Switch Downstream Port
[ 6.543203] [TS:60479576516] pci 0001:02:04.0: [12d8:2608] type 01 class 0x060400 PCIe Switch Downstream Port
[ 6.543892] [TS:60480264978] pci 0001:02:05.0: [12d8:2608] type 01 class 0x060400 PCIe Switch Downstream Port
[ 6.546406] [TS:60482779016] pci 0001:03:00.0: [10ec:8168] type 00 class 0x020000 PCIe Endpoint
[ 6.547384] [TS:60483757108] pci 0001:35:00.0: [10ec:8168] type 00 class 0x020000 PCIe Endpoint
[ 6.548359] [TS:60484732664] pci 0001:67:00.0: [1c00:3450] type 00 class 0x070005 PCIe Legacy Endpoint
[ 6.549093] [TS:60485466108] pci 0001:99:00.0: [1a03:1150] type 01 class 0x060400 PCIe to PCI/PCI-X bridge
[ 6.568311] [TS:60504684284] pcieport 0001:00:00.0: Adding to iommu group 13
[ 6.569047] [TS:60505420080] pcieport 0001:00:00.0: PME: Signaling with IRQ 168
[ 6.569967] [TS:60506340108] pcieport 0001:00:00.0: AER: enabled with IRQ 155
[ 6.570236] [TS:60506609516] pcieport 0001:00:00.0: DPC: enabled with IRQ 154
[ 6.570239] [TS:60506612108] pcieport 0001:00:00.0: DPC: error containment capabilities: Int Msg #1, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 6.584063] [TS:60520436682] pcieport 0001:01:00.0: Adding to iommu group 14
[ 6.584177] [TS:60520550756] pcieport 0001:01:00.0: enabling device (0000 -> 0003)
[ 6.594049] [TS:60530422293] pcieport 0001:02:01.0: Adding to iommu group 15
[ 6.594196] [TS:60530569904] pcieport 0001:02:01.0: enabling device (0000 -> 0003)
[ 6.594374] [TS:60530747571] pcieport 0001:02:01.0: pciehp: Slot #0 AttnBtn+ PwrCtrl+ MRL+ AttnInd+ PwrInd+ HotPlug+ Surprise- Interlock- NoCompl- IbPresDis- LLActRep+
[ 6.595918] [TS:60532291719] pcieport 0001:02:02.0: Adding to iommu group 16
[ 6.596365] [TS:60532738247] pcieport 0001:02:02.0: enabling device (0000 -> 0003)
[ 6.596552] [TS:60532925793] pcieport 0001:02:02.0: pciehp: Slot #0 AttnBtn+ PwrCtrl+ MRL+ AttnInd+ PwrInd+ HotPlug+ Surprise- Interlock- NoCompl- IbPresDis- LLActRep+
[ 6.597813] [TS:60534186293] pcieport 0001:02:03.0: Adding to iommu group 17
[ 6.598418] [TS:60534791636] pcieport 0001:02:03.0: enabling device (0000 -> 0003)
[ 6.598586] [TS:60534959284] pcieport 0001:02:03.0: pciehp: Slot #0 AttnBtn+ PwrCtrl+ MRL+ AttnInd+ PwrInd+ HotPlug+ Surprise- Interlock- NoCompl- IbPresDis- LLActRep+
[ 6.600262] [TS:60536635525] pcieport 0001:02:04.0: Adding to iommu group 18
[ 6.600384] [TS:60536757682] pcieport 0001:02:04.0: enabling device (0000 -> 0003)
[ 6.600541] [TS:60536914849] pcieport 0001:02:04.0: pciehp: Slot #0 AttnBtn+ PwrCtrl+ MRL+ AttnInd+ PwrInd+ HotPlug+ Surprise- Interlock- NoCompl- IbPresDis- LLActRep+
[ 6.601518] [TS:60537891201] pcieport 0001:02:05.0: Adding to iommu group 19
[ 6.602106] [TS:60538478997] pcieport 0001:02:05.0: enabling device (0000 -> 0003)
[ 6.602302] [TS:60538675349] pcieport 0001:02:05.0: pciehp: Slot #0 AttnBtn+ PwrCtrl+ MRL+ AttnInd+ PwrInd+ HotPlug+ Surprise- Interlock- NoCompl- IbPresDis- LLActRep+
[ 6.673057] [TS:60609430016] pcieport 0001:99:00.0: Adding to iommu group 21
[ 6.735873] [TS:60672246562] tegra264-pcie a808420000.pcie: host bridge /bus@0/pcie@a808420000 ranges:
[ 6.735885] [TS:60672258256] tegra264-pcie a808420000.pcie: MEM 0x0030000000..0x0037ffffff -> 0x0030000000
[ 6.735894] [TS:60672267191] tegra264-pcie a808420000.pcie: MEM 0xb0c0000000..0xb87fffffff -> 0xb0c0000000
[ 6.735899] [TS:60672272525] tegra264-pcie a808420000.pcie: IO 0xb084000000..0xb0841fffff -> 0x0084000000
[ 6.735981] [TS:60672354053] tegra264-pcie a808420000.pcie: ECAM at [mem 0xb0b0000000-0xb0bfffffff] for [bus 00-ff]
[ 6.841183] [TS:60777556136] tegra264-pcie a808420000.pcie: PCIe Controller-2 Link is UP (Speed: 4)
[ 6.841319] [TS:60777692775] tegra264-pcie a808420000.pcie: PCI host bridge to bus 0002:00
[ 6.841367] [TS:60777740312] pci 0002:00:00.0: [10de:22d8] type 01 class 0x060400 PCIe Root Port
[ 6.844049] [TS:60780422191] pci 0002:01:00.0: [1d79:2264] type 00 class 0x010802 PCIe Endpoint
[ 6.844401] [TS:60780774090] pci 0002:01:00.0: 31.506 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x2 link at 0002:00:00.0 (capable of 63.012 Gb/s with 16.0 GT/s PCIe x4 link)
[ 6.871232] [TS:60807605293] pcieport 0002:00:00.0: Adding to iommu group 22
[ 6.872204] [TS:60808577219] pcieport 0002:00:00.0: PME: Signaling with IRQ 193
[ 6.872733] [TS:60809106006] pcieport 0002:00:00.0: AER: enabled with IRQ 180
[ 6.873082] [TS:60809454960] pcieport 0002:00:00.0: DPC: enabled with IRQ 179
[ 6.873084] [TS:60809457386] pcieport 0002:00:00.0: DPC: error containment capabilities: Int Msg #1, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 6.873349] [TS:60809722201] tegra264-pcie a808440000.pcie: host bridge /bus@0/pcie@a808440000 ranges:
[ 6.873362] [TS:60809735071] tegra264-pcie a808440000.pcie: MEM 0x0038000000..0x003fffffff -> 0x0038000000
[ 6.873371] [TS:60809744627] tegra264-pcie a808440000.pcie: MEM 0xb8c0000000..0xc07fffffff -> 0xb8c0000000
[ 6.873377] [TS:60809750117] tegra264-pcie a808440000.pcie: IO 0xb884000000..0xb8841fffff -> 0x0084000000
[ 6.873487] [TS:60809860812] tegra264-pcie a808440000.pcie: ECAM at [mem 0xb8b0000000-0xb8bfffffff] for [bus 00-ff]
[ 6.977197] [TS:60913570154] tegra264-pcie a808440000.pcie: PCIe Controller-3 Link is UP (Speed: 2)
[ 6.977334] [TS:60913707275] tegra264-pcie a808440000.pcie: PCI host bridge to bus 0003:00
[ 6.977387] [TS:60913760275] pci 0003:00:00.0: [10de:22da] type 01 class 0x060400 PCIe Root Port
[ 6.980197] [TS:60916570062] pci 0003:01:00.0: [1b4b:9235] type 00 class 0x010601 PCIe Legacy Endpoint
[ 6.989112] [TS:60925485219] pcieport 0003:00:00.0: Adding to iommu group 23
[ 6.990245] [TS:60926618627] pcieport 0003:00:00.0: PME: Signaling with IRQ 209
[ 6.991329] [TS:60927702367] pcieport 0003:00:00.0: AER: enabled with IRQ 196
[ 6.991896] [TS:60928269358] pcieport 0003:00:00.0: DPC: enabled with IRQ 195
[ 6.991899] [TS:60928272284] pcieport 0003:00:00.0: DPC: error containment capabilities: Int Msg #1, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 6.992676] [TS:60929049173] tegra264-pcie a808460000.pcie: host bridge /bus@0/pcie@a808460000 ranges:
[ 6.992688] [TS:60929061636] tegra264-pcie a808460000.pcie: MEM 0x0040000000..0x0047ffffff -> 0x0040000000
[ 6.992697] [TS:60929070895] tegra264-pcie a808460000.pcie: MEM 0xc0c0000000..0xc87fffffff -> 0xc0c0000000
[ 6.992703] [TS:60929076265] tegra264-pcie a808460000.pcie: IO 0xc084000000..0xc0841fffff -> 0x0084000000
[ 6.992794] [TS:60929167432] tegra264-pcie a808460000.pcie: ECAM at [mem 0xc0b0000000-0xc0bfffffff] for [bus 00-ff]
[ 7.097006] [TS:61033379025] tegra264-pcie a808460000.pcie: PCIe Controller-4 Link is UP (Speed: 5)
[ 7.097137] [TS:61033510228] tegra264-pcie a808460000.pcie: PCI host bridge to bus 0004:00
[ 7.097186] [TS:61033559534] pci 0004:00:00.0: [10de:22d6] type 01 class 0x060400 PCIe Root Port
[ 7.099901] [TS:61036274821] pci 0004:01:00.0: [15b3:1979] type 01 class 0x060400 PCIe Switch Upstream Port
[ 7.101436] [TS:61037809627] pci 0004:02:00.0: [15b3:1979] type 01 class 0x060400 PCIe Switch Downstream Port
[ 7.102910] [TS:61039283793] pci 0004:02:01.0: [15b3:1979] type 01 class 0x060400 PCIe Switch Downstream Port
[ 7.104396] [TS:61040769645] pci 0004:02:02.0: [15b3:1979] type 01 class 0x060400 PCIe Switch Downstream Port
[ 7.107842] [TS:61044214978] pci 0004:03:00.0: [15b3:1021] type 00 class 0x020000 PCIe Endpoint
[ 7.109512] [TS:61045885265] pci 0004:03:00.0: VF BAR 0 [mem 0xc0d8000000-0xc0d9ffffff 64bit pref]: contains BAR 0 for 16 VFs
[ 7.110734] [TS:61047107543] pci 0004:03:00.0: 252.056 Gb/s available PCIe bandwidth, limited by 32.0 GT/s PCIe x8 link at 0004:00:00.0 (capable of 504.112 Gb/s with 32.0 GT/s PCIe x16 link)
[ 7.111581] [TS:61047954775] pci 0004:03:00.1: [15b3:1021] type 00 class 0x020000 PCIe Endpoint
[ 7.114982] [TS:61051355738] pci 0004:04:00.0: [15b3:1979] type 01 class 0x060400 PCIe Switch Upstream Port
[ 7.117031] [TS:61053404349] pci 0004:04:00.0: 252.056 Gb/s available PCIe bandwidth, limited by 32.0 GT/s PCIe x8 link at 0004:00:00.0 (capable of 504.112 Gb/s with 32.0 GT/s PCIe x16 link)
[ 7.118321] [TS:61054694488] pci 0004:05:08.0: [15b3:1979] type 01 class 0x060400 PCIe Switch Downstream Port
[ 7.123885] [TS:61060258858] pci 0004:07:00.0: [15b3:1979] type 01 class 0x060400 PCIe Switch Upstream Port
[ 7.126440] [TS:61062813312] pci 0004:07:00.0: 252.056 Gb/s available PCIe bandwidth, limited by 32.0 GT/s PCIe x8 link at 0004:00:00.0 (capable of 504.112 Gb/s with 32.0 GT/s PCIe x16 link)
[ 7.127199] [TS:61063572228] pci 0004:08:00.0: [15b3:1979] type 01 class 0x060400 PCIe Switch Downstream Port
[ 7.131364] [TS:61067737636] pci 0004:09:00.0: [10de:2bb4] type 00 class 0x030000 PCIe Legacy Endpoint
[ 7.131962] [TS:61068335238] pci 0004:09:00.0: 252.056 Gb/s available PCIe bandwidth, limited by 32.0 GT/s PCIe x8 link at 0004:00:00.0 (capable of 504.112 Gb/s with 32.0 GT/s PCIe x16 link)
[ 7.132215] [TS:61068588164] pci 0004:09:00.1: [10de:22e8] type 00 class 0x040300 PCIe Endpoint
[ 7.161089] [TS:61097462719] pcieport 0004:00:00.0: Adding to iommu group 24
[ 7.162128] [TS:61098501793] pcieport 0004:00:00.0: PME: Signaling with IRQ 225
[ 7.163750] [TS:61100123071] pcieport 0004:00:00.0: AER: enabled with IRQ 212
[ 7.164616] [TS:61100989849] pcieport 0004:00:00.0: DPC: enabled with IRQ 211
[ 7.164619] [TS:61100992654] pcieport 0004:00:00.0: DPC: error containment capabilities: Int Msg #1, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 7.202073] [TS:61138446701] pcieport 0004:01:00.0: Adding to iommu group 25
[ 7.202281] [TS:61138654599] pcieport 0004:01:00.0: enabling device (0106 -> 0107)
[ 7.228056] [TS:61164429302] pcieport 0004:02:00.0: Adding to iommu group 26
[ 7.228909] [TS:61165282377] pcieport 0004:02:01.0: Adding to iommu group 27
[ 7.229449] [TS:61165822034] pcieport 0004:02:02.0: Adding to iommu group 28
[ 7.229549] [TS:61165922571] pcieport 0004:02:02.0: enabling device (0106 -> 0107)
[ 7.256020] [TS:61192393117] pcieport 0004:04:00.0: Adding to iommu group 27
[ 7.282027] [TS:61218400469] pcieport 0004:05:08.0: Adding to iommu group 27
[ 7.300019] [TS:61236392182] pcieport 0004:07:00.0: Adding to iommu group 28
[ 7.300139] [TS:61236512617] pcieport 0004:07:00.0: enabling device (0106 -> 0107)
[ 7.318023] [TS:61254395978] pcieport 0004:08:00.0: Adding to iommu group 28
[ 7.318151] [TS:61254524219] pcieport 0004:08:00.0: enabling device (0106 -> 0107)
[ 7.798334] [TS:61734707330] mlx5_core 0004:03:00.0: 252.056 Gb/s available PCIe bandwidth, limited by 32.0 GT/s PCIe x8 link at 0004:00:00.0 (capable of 504.112 Gb/s with 32.0 GT/s PCIe x16 link)
[ 8.172576] [TS:62108949061] mlx5_core 0004:03:00.0: mlx5_pcie_event:325:(pid 11): PCIe slot power capability was not advertised.
[ 8.274439] [TS:62210812423] mlx5_core 0004:03:00.1: 252.056 Gb/s available PCIe bandwidth, limited by 32.0 GT/s PCIe x8 link at 0004:00:00.0 (capable of 504.112 Gb/s with 32.0 GT/s PCIe x16 link)
[ 8.648097] [TS:62584470756] mlx5_core 0004:03:00.1: mlx5_pcie_event:325:(pid 688): PCIe slot power capability was not advertised.
[ 15.083814] [TS:69020186958] systemd[1]: /etc/systemd/system/wifi-pcie-fix.service:11: Missing '=', ignoring line.
[ 18.190949] [TS:72127322486] input: HDA NVidia HDMI/DP,pcm=3 as /devices/platform/bus@0/a808460000.pcie/pci0004:00/0004:00:00.0/0004:01:00.0/0004:02:02.0/0004:07:00.0/0004:08:00.0/0004:09:00.1/sound/card1/input11
[ 18.191904] [TS:72128277689] input: HDA NVidia HDMI/DP,pcm=7 as /devices/platform/bus@0/a808460000.pcie/pci0004:00/0004:00:00.0/0004:01:00.0/0004:02:02.0/0004:07:00.0/0004:08:00.0/0004:09:00.1/sound/card1/input12
[ 18.195029] [TS:72131402245] input: HDA NVidia HDMI/DP,pcm=8 as /devices/platform/bus@0/a808460000.pcie/pci0004:00/0004:00:00.0/0004:01:00.0/0004:02:02.0/0004:07:00.0/0004:08:00.0/0004:09:00.1/sound/card1/input13
[ 18.198469] [TS:72134842319] input: HDA NVidia HDMI/DP,pcm=9 as /devices/platform/bus@0/a808460000.pcie/pci0004:00/0004:00:00.0/0004:01:00.0/0004:02:02.0/0004:07:00.0/0004:08:00.0/0004:09:00.1/sound/card1/input14
[ 19.140565] [TS:73076938374] Bluetooth: hci0: RTL: examining hci_ver=0c hci_rev=000c lmp_ver=0c lmp_subver=8852
[ 19.142560] [TS:73078933846] Bluetooth: hci0: RTL: rom_version status=0 version=1
[ 19.142567] [TS:73078940513] Bluetooth: hci0: RTL: loading rtl_bt/rtl8852cu_fw_v2.bin
[ 19.187306] [TS:73123678976] Bluetooth: hci0: RTL: loading rtl_bt/rtl8852cu_config.bin
[ 19.192600] [TS:73128973152] Bluetooth: hci0: RTL: cfg_sz 6, total sz 71983
[ 19.845539] [TS:73781912624] Bluetooth: hci0: RTL: fw version 0x040d7225
[ 35.305013] [TS:89241386982] VDD_3V3_WIFI: disabling
enxce1d2ae95aa4 ethernet disconnected --
$ rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
Thanks!!
