Hello NVIDIA IGX Support team,
I am setting up a new NVIDIA IGX Thor Developer Kit/T7000 by following the official installation guide:
After connecting to the BMC WebUI and changing the default password, the WebUI continuously displays:
BMC is still initializing. Use at your own risk.
I waited for initialization to complete, but the condition persists. Both the WebUI and SSH remain accessible at 192.168.1.110.
My issue appears to match this recently resolved case very closely:
In particular, I see the same Redfish state, failed services, and repeated OTP provisioning error.
Redfish Manager status
Status: {
'Conditions': [],
'Health': 'OK',
'HealthRollup': 'OK',
'State': 'Starting'
UptimeSeconds: None
Therefore, although health is reported as OK, the Manager never transitions from Starting to Enabled, and UptimeSeconds is not populated.
BMC firmware information
Output of cat /etc/os-release:
ID=openbmc-phosphor
NAME="NVIDIA IGX BMC (OpenBMC Project Reference Distro)"
VERSION="IGX-BMC-v5.4"
VERSION_ID=igx-bmc-v5.4-0-g30b2fa7cc1c.1771514149.9507709
VERSION_CODENAME="scarthgap"
PRETTY_NAME="NVIDIA IGX BMC (OpenBMC Project Reference Distro) IGX-BMC-v5.4"
CPE_NAME="cpe:/o:openembedded:openbmc-phosphor:IGX-BMC-v5.4-0-g30b2fa7cc1c.1771514149.9507709"
BUILD_ID="20260219151545"
OPENBMC_TARGET_MACHINE="igx-3809"
EXTENDED_VERSION="IGX-BMC-v5.4-0-g30b2fa7cc1c"
BUILD_DESC="debug-platform"
Failed BMC services
Output of systemctl --failed --no-pager:
UNIT LOAD ACTIVE SUB DESCRIPTION
proc-fs-nfsd.mount loaded failed failed NFSD configuration filesystem
delete-hi-user.service loaded failed failed Delete Host Interface User
mctp-pcie-ctrl.service loaded failed failed MCTP PCIe control daemon
system-guid.service loaded failed failed Get System Guid
4 loaded units listed.
Repeated journal error
journalctl -f repeatedly prints the following message, approximately every five seconds:
bmcweb[297]: [ERROR managers.hpp:3598] Failed to open OTP provisioning status file
I also occasionally see:
bmcweb[297]: [ERROR update_service.hpp:3869] error_code = Invalid request descriptor [generic:53], error msg = Invalid request descriptor
The journal entries currently have timestamps beginning on February 27.
Actions performed
Connected the host directly to the correct BMC Ethernet port.
Configured the host Ethernet interface and successfully accessed
192.168.1.110. -
Successfully accessed both the BMC WebUI and BMC SSH shell.
Changed the default BMC password.
Waited for initialization to complete.
Collected the Redfish, systemd, firmware-version, and journal information above.
I have paused the setup before attempting any firmware write. I have not factory-reset the BMC, manually modified the BMC filesystem, or manually flashed BMC, SMCU, or QSPI firmware.
The matching forum case reports that updating the SMCU ultimately resolved the problem. I also noticed that the IGX-SW 2.0 release notes warn against using smcu-auto-flash.sh with this BMC release.
Before proceeding, could you please confirm:
Is it safe and recommended to update the SMCU through the BMC WebUI while the Redfish Manager remains in the
Startingstate? -
Should I use exactly
smcu-flash.fwpkgfrom the officialigx_fw_for_webui_update_R38.5.0.tbz2bundle? -
Should I perform a complete AC power cycle before the SMCU update?
Are there any additional read-only diagnostics you would like me to collect first?
Does
BUILD_DESC="debug-platform"represent the expected factory firmware for this Developer Kit?
I can provide the full journal, service-status output, firmware-inventory screenshots, board part number, and serial number privately if required.
Thank you.
