I'm begging for support on flashing orin nx reporting error ERROR: might be timeout in USB write
I can’t resolve this error when flashing orin nx 16g, I’ve tried many measures but can’t resolve it, including:
  • Replacing the devkit
  • Replacing the usb cable
  • Disable usb autosuspend.
  • Replacing 20.04 with 18.04 host machine
  • Replacing 5.1.1 jatpack with 5.1.3 jatpack
  • Replace 5.1.1 jatpack with 5.1.3 JatPack using version 2.0.0.11405, sdkmanager, or flashing from the command line.
    At this stage it always reports this error at the end, I kindly ask if you can give me some support, the text of the error message and the export are as follows.
 Entering RCM boot
[   0.0182 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin
[   0.0182 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin
[   0.0182 ] rcm boot with presigned binaries
[   0.0188 ] tegrarcm_v2 --instance 1-6 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.0194 ] BR_CID: 0x80012344705DD5D17400000013FE8040
[   0.0254 ] Sending bct_br
[   0.0305 ] Sending mb1
[   0.0310 ] Sending psc_bl1
[   0.0407 ] Sending bct_mb1
[   0.0465 ] Generating blob for T23x
[   0.0476 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[   0.0481 ] The number of images in blob is 18
[   0.0483 ] blobsize is 73439485
[   0.0483 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 3182656
[   0.0692 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 375168
[   0.0695 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 190592
[   0.0696 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 277312
[   0.0697 ] Not supported type: mb2_applet
[   0.0698 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 437984
[   0.0699 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164352
[   0.0700 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 9097216
[   0.0731 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[   0.0739 ] Added binary blob_bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt of size 1048000
[   0.0742 ] Added binary blob_tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt of size 138880
[   0.0744 ] Added binary blob_camera-rtcpu-sce_sigheader.img.encrypt of size 166304
[   0.0744 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 537952
[   0.0746 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 400960
[   0.0746 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[   0.0747 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1064752
[   0.0751 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[   0.0752 ] Added binary blob_boot0.img of size 55437312
[   0.0954 ] Added binary blob_tegra234-p3767-0000-p3509-a02.dtb of size 344461
[   0.1270 ] tegrarcm_v2 --instance 1-6 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[   0.1275 ] BL: version 0.32.0.0-t234-54845784-57325615 last_boot_error: 0
[   0.2751 ] Sending bct_mem
[   0.2946 ] Sending blob
[   0.3786 ] ERROR: might be timeout in USB write.
Error: Return value 3
Command tegrarcm_v2 --instance 1-6 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
Cleaning up...
[SDKM_logs_JetPack_5.1.1_(rev._1)_Linux_for_Jetson_Orin_NX_modules_2024-03-11_14-36-44.zip|attachment](upload://bF1RtBlZpShTgOLH9rcBNoenwXm.zip) (330.5 KB)
SDKM_logs_JetPack_5.1.1_(rev._1)_Linux_for_Jetson_Orin_NX_modules_2024-03-11_14-36-44.zip (330.5 KB)
Is it possible to dump the UART log from the Jetson Orin NX during flashing?
Dump the log, please:
