I'm following example of DIGITS, object-detection
I’m following object detection example.
When I trained the network using pre-trained GoogleNet(.caffemodel) you linked, using epoch 10.
And I cloned the Job and trained Again.
I didn’t change any options, but the result is different.
The difference is not a little.
The first model’s mAP is 42, but the second model’ mAP is 0.
Why the difference is occurred.
I just clicked ‘clone job’ and ‘create’.
