I want to know which algorithm I use has enough performance for Jetson tx2. But I don’t know which of Jetson’s specifications should be considered. If you use algorithms that are too high-performance, it will be too much for Jetson. I want you to tell me what to consider or recommend a face recognition algorithm that can be used as a Jetson tx2. Thanks.
It’s recommended to give our sample a try:
https://github.com/dusty-nv/jetson-inference
It contains several detectors and classifiers which may meet your requirement. (Maybe you need both)
Thanks. But there is no information about Jetson TX2. I need information about Jetson TX2.
The sample can also be used on TX2.
For benchmark information, we don’t have too much performance for TX2 currently.
You can just give it a try.
