I'm having trouble deploying VLLM with a mirror in Jetson Orin NX
I ran the image using the official HF commands, but my container failed to start.
The issue likely stems from a mismatched CUDA version. What baffles me is that Jetpack’s proprietary CUDA version can’t be modified and is capped at 12.6, yet the image requires CUDA 12.8-this is absurd.
Can someone tell me how to use VLLM on Jetson Orin NX?
Please use the container below instead:
I’m currently using the official Docker image, but the command to run it on hf still gives an error.
~0106
The error shows that it cannot find the model path.
Could you double-confirm it?
