I am trying to decode via UDP in H265 with ultra-low-latency mode, for encoding I am using a VITEC encoder.
I launch the following code:
gst-launch-1.0 udpsrc address=225.1.1.1 multicast-iface=eth0 port=30120 ! typefind ! tsdemux ! multiqueue ! h265parse ! capsfilter caps='video/x-h265, stream-format=byte-stream' ! nvv4l2decoder ! nvvidconv ! 'video/x-raw(memory:NVMM),format=(string)NV12' ! videoconvert ! autovideosink sync=false
I have the following output
0:00:09.074792416 11134 0x7f90056d40 WARN h265parse gsth265parse.c:1063:gst_h265_parse_handle_frame:<h265parse0> broken/invalid nal Type: 38 FD, Size: 4 will be dropped NvMMLiteOpen : Block : BlockType = 279 NVMEDIA: Reading vendor.tegra.display-size : status: 6 NvMMLiteBlockCreate : Block : BlockType = 279 0:00:09.184232512 11134 0x7f90056d40 WARN v4l2 gstv4l2object.c:3300:gst_v4l2_object_save_format:<nvv4l2decoder0:src> Driver bug detected, stride (640) is too small for the width (1280) 0:00:09.184340128 11134 0x7f90056d40 WARN v4l2 gstv4l2object.c:4434:gst_v4l2_object_probe_caps:<nvv4l2decoder0:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1 0:00:09.184389824 11134 0x7f90056d40 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:src> Unable to try format: Unknown error -1 0:00:09.184425152 11134 0x7f90056d40 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:src> Could not probe minimum capture size for pixelformat PM10 0:00:09.184452512 11134 0x7f90056d40 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:src> Unable to try format: Unknown error -1 0:00:09.184557792 11134 0x7f90056d40 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:src> Could not probe maximum capture size for pixelformat PM10 0:00:09.184873824 11134 0x7f90056d40 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x55a1874cc0 Failed to determine interlace mode 0:00:09.184965472 11134 0x7f90056d40 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x55a1874cc0 Failed to determine interlace mode 0:00:09.199535456 11134 0x7f90056d40 WARN v4l2videodec gstv4l2videodec.c:1673:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder0> Duration invalid, not setting latency 0:00:09.200177312 11134 0x7f90056d40 WARN v4l2bufferpool gstv4l2bufferpool.c:1066:gst_v4l2_buffer_pool_start:<nvv4l2decoder0:pool:src> Uncertain or not enough buffers, enabling copy threshold 0:00:09.381094464 11134 0x55a1879140 WARN tsdemux tsdemux.c:2359:gst_ts_demux_queue_data: CONTINUITY: Mismatch packet 7, stream 15
I cannot see the video, I only receive the data packet of the last line.
This happens when I try to capture the video with the encoder broadcasting. If I start the gstreamer process before the encoder starts broadcasting, once I start receiving, I play the video without problem.
The same goes for the DeepStream, if I launch it with the encoder emitting, I get a black screen.
This problem only happens to me with the ultra-low-latency mode activated. With ultra low latency turned off I can watch the video anyway.
Any solution?
Thanks a lot
