I use IMX304m camera (MIPI camera), which is monochrome, encoded on 12 bit.
I need to implement the process below :
1- take x times the same image of an object ;
2- change the position of the object ;
1- take x times the same image of the object in its new position ;
To implement it, I would like to use libargus.
For all images, I need to extract pixels’ value from the raw pointer to an unsigned short . I didn’t find in the samples /usr/src/tegra_multimedia_api/samples how access to the raw pointer, and how access pixels. Maybe is there a process already implemented in libargus ?
Moreover, do you provide a sample close to my application ? I didn’t find anything.
I have an other question. I have a monochrome camera, and the sample write .jpg as rgb image. Why ? Notice that is RV12 format.
Thank you
