I want to just update the rootfs, but the jetpack version still doesn’t change. Can it be achieved through the ota base image, because when I try to upgrade from jetpack R35.1 to R35.1, the program prompts that it is not supported. If not, may I ask if there is a proper way to update only the rootfs. thanks
Target board(JETSON_XAVIER_NX_DEVKIT) and base version(R35_1) is not supported
Failed to run “ota_validate_params jetson-xavier-nx-devkit R35-1 internal /home/lw/Workspace/nvidia/R35.1/Linux_for_Tegra/tools/ota_tools/version_upgrade/ota_board_specs.conf BOARD_SPECS_ARRAY CHIPID”
Usage: sudo ./tools/ota_tools/version_upgrade/l4t_generate_ota_package.sh [options]
Where,
: target board. Supported boards: jetson-agx-xavier-devkit, jetson-xavier-nx-devkit-emmc.
: the version of the base BSP. Supported versions: R32-7.
options:
-u : PKC key used for odm fused board
-v : Secure Boot Key (SBK) key used for ODM fused board
-s Skip generating system image.
-b Update bootloader only. Only valid for update without layout change.
-r Update rootfs only. Only valid for update without layout change.
-o Specify the script to update rootfs partition.
-f Specify the rootfs image to be written to rootfs partition.
Example:
sudo ./tools/ota_tools/version_upgrade/l4t_generate_ota_package.sh -u PKCkeyfile -v SBKkeyfile jetson-xavier-nx-devkit-emmc R32-7
