Hi, ShaneCCC
I recently lit up a monochrome bayer RAW sensor on TX2,the captured image is pink.
Could you please tell me how can I get a normal black and white image?
I refered this topic but it’s doesn’t work well.
[type or paste code here](https://forums.developer.nvidia.com/t/the-feasibility-of-high-frame-rate-camera-input-on-jetson-agx-xavier/187004)
ShaneCCC
Moderator
Aug 23
You can just report it as normal RGB bayer sensor and create camera_overrides.isp at /var/nvidia/nvcam/settings/
Also need change the file attribute to 644 by sudo chmod 644 camera_overrides.isp
demosaic.v5.family.use=CCCC
defaults.yuvMatrix[0] = {0.3333, 0.3333, 0.3333, 0};
defaults.yuvMatrix[1] = {0, 0, 0, 0};
defaults.yuvMatrix[2] = {0, 0, 0, 0};
defaults.yuvMatrix[3] = {0, 0, 0, 1};
BTW,Are there more detailed instructions for using camera_overide.isp.
Like how to adjust the BLC,WB,CCM,Lens shading,Such as this
Thank you and Best Regards.
An error occurred after the command was executed : 725 No cameras available
The camera can open normally after deleting camera_overide.isp files.
Tx2 L4T version is 32.6.1.
