image_channel_order for Ultrasound image
Hi all,
i wanna to creat a image memory object for ultrasound image (post-processed, stored in frames). Which kind of image_channel_order should i use? CL_INTENSITY or CL_LUNINANCE or what else?. Thanks
I believe the meaning is the same as in OpenGL, so maybe this posts helps to find an answer:
http://www.opengl.org/discussion_boards/ubbthreads.php?ubb=showflat&Number=161204#Post161204
In short, use luminance (as you don’t need alpha).
Thank you!!!
