Image corruption / abnormal color pixels within camera frames on Jetson
Hi NVIDIA team,
We are seeing an image corruption issue with our camera stream on Jetson.
The frame structure is still correct and the objects in the scene are clearly recognizable. However, there are many abnormal green/blue/cyan pixels distributed across the image, as shown in the attached screenshot.
The corruption occurs within the frame, while the frame itself does not appear to be shifted, torn, or lost.
Could you please advise what could cause this type of pixel corruption on the Jetson camera pipeline?
Does this symptom look more related to:
What logs or traces should we collect to narrow down the root cause?
Attached is a screenshot showing the issue.
I
sg_zcm2057nmi_driver_device_tree.zip (6.2 KB)
have attached the two files I am currently using for this camera configuration:
  • Camera driver: sg_zcm2057nmi.c
  • Device tree: tegra234-camera-sg_zcm2057nmi-portC-2lane-1920x1080-60.dts
These are the driver and device-tree configurations currently used on my Jetson setup.
Please help review whether there is any incorrect configuration that could cause the image corruption shown above.
Looks like the sensor output the noise doesn’t like ISP process cause the problem.
Could you check by jpeg by nvargus_nvraw
I’ve double-checked, and the issue was with my hardware; thanks for your help.
